Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Can't use new washer
The washer works fine but it drains too fast...the water comes right back up the pipe and all over the floor. We tried putting a long hose on it but that didn't solve the problem...still doing it. Is this something that can be fixed or should I return the thing?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to fix your plumbing is what it sounds like,lengthen the drian standpipe, not the drain hose.
Posted on Apr 06, 2008
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
Replace drain hose
if u add an extension to the drain hose it will take a long time to and go down the pvc pipe. Just check for clog. by giving it for service one time may work.
Nov 03, 2013 | Maytag Performa PAV2200
Whirlpool WTW5520SQ0, when draining the water is coming out at such a fast rate it's backing out of pipe and on the floor.
For many of the new washers you need to have a 2" standpipe and trap... the older 1-1/2" standpipes and traps will not handle the higher volume of the new pumps...
heatman101
May 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The water fills and drain from the bottom of the washing machine. Have checked all the pipes no problem. Please advice
front load or top ? drain hose must be elevated to 36 '' 34 min. if hose on floor it will not work .. needs stand pipe . if its leaking inside you may have a hose off . reinstall and wala it works .. mm hope some of ans work for you ..
Dec 03, 2009 | Ovens
Ge FRONT LOADER WASHING MACHINE DRAINS TOO FAST AND IT OVERFLOWS OUT OF THE DRAIN PIPE ONTO THE FLOOR. IT HAS 1 5/8" DIAMETER DRAIN PIPE. SOLUTIONS???
Yes, the new front loaders do drain much faster...I find that you need to have a 2" drain for them to work properly without over flowing the standpipe.
Now, what can you do??
You can add on to the standpipe and get it up higher, this will do two things... the higher lift will slow down the pump a bit, but will make it work harder and possibly fail quicker...the higher stadpipe will give you a bit more reserve space for the water to collect and then flow down and catchup after the intial burst of flow from the pump. The higher pipe will also create a bit more pressure to push the water down the pipe.
The next and better fix would be to install a bigger standpipe and trap. Go right back the the main line and run a new 2" line and trap to the washer.
I assume that you checked the existing pipe and trap for blockage....but thought I better throw that out there...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | GE WSXH208A Front Load Washer
My washing machine seems to work just fine, but right at the beginning of the drainage cycle, the water comes flowing up the tube as it should but quite a bit of it ends up on the floor. It's like the...
A properly clear outlet pipe should be able to cope with the output of a washing machine. If not it is partially blocked. try hooking the outlet pipe over the side of the laundry sink, If this works......leave it that way until you figure out who is going to unblock the outlet pipe.
Oct 20, 2009 | Kenmore 44102 Front Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Spin problems
sorry appl_doctor but i already that one too .... the hose goes into a deep sink but it wasnt in a new position since i put it in seven yrs ago ..... but just in case the sink may have been backing up i moved it to a hard pipe that then goes to the sink but the end of the pipe is waaaaay abv any posibl water level .... but low enuff for the washer to drain properly but thnx anyway .... sapperstein
Feb 12, 2008 | Whirlpool GST9679P Top Load Washer
Washing machine will not drain
There is a corrigated plastic hose (usually black or white) that comes out the back of the washer that should lead to some sort of drain (usually a pipe that comes out of the floor or in a recessed wall. If the washer is in a basement or place that you don't mind the water getting on the floor, remove the hose from the pipe and just set it on the floor or put the hose in a bucket. It will be SEVERAL bucket fulls. That will drain about 95% of the water. if this works, that means the pump is out. If you do that and no water or if the water just tickles out, you have a clog in the hose or the pump.
Dec 23, 2007 | Washing Machines
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
