Need to replace the light bulb in a Gemini PT-2000 turntable target light.
  • 1,512 Answers
Hi Scotty
Just go for it man... The light is a pop assembly, so you will have to go in from the bottom to get access to it. Searched for a service manual to link to you, but not much out there. Do you have a multimeter to do a few DC checks?
Posted on Apr 06, 2008
SOURCE:
Where in the UK can I find a replacement target light bulb for a Gemini PT-1000 II ??
It is replaced with an LED. Any Disco supplies store should be able to advise. Similar to the Technics SL1200 series.
Jun 05, 2018 | Gemini Audio Players & Recorders
I need a power lead
The power cord looks like this is a standard PC/Kettle power cord. Otherwise the connecting cables should be just standard phone cables. have a look at the image here..
http://medias.audiofanzine.com/images/normal/gemini-dj-pt-2000-185179.jpg
May 21, 2014 | Gemini DJ Gemini Pt2000 Turntables
I plugged my gemini pt-1000 turntable into the aux in the back of my stereo, but the sound is very low. Do I need a preamp?
If the amp doesn't have an imput marked phono, or deck, or turntable, the answer is yes. Search for a 'magnetic cartridge pre-amp' via google.
Feb 26, 2011 | Gemini PT-1000 II Turntable
How to remove the platter in Gemini PT-2400 Turntable
hi,
firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
ok
Dec 30, 2010 | Gemini PT-2400 Turntable
Why Fry - 220 or 110 ????
You should be fine with this. Here is the spec:
Quartz lock large blue LCD display showing: speed, pitch & platter direction, locking platter reverse button, located in battle position, 3-speed design: 33, 45 & 78 RPM, 7 grams of anti-skate adjustment, adjustable pitch control+= 10 & pitch bend buttons, locking reverse button, hi-tech tone arm with height adjustment, feather-touch start/ stop control, strobe illuminator, pop-up target light, headshell, slipmat and dustcover included . 115V/230V switchable. 17.75"w x 6"h x 14"d. Weight:27lbs.
Jul 18, 2010 | Gemini PT-2410 Turntable
Would it be extraordinarily difficult to replace the tone arm on a gemini pt-2000 turntable?
I,ve never done a gemini pt-2000 but i've done a technics 12/10 & trust me mate it's a proper pane in the arse.
But like i said
I've never done a pt-2000....
Aug 03, 2009 | Audio Players & Recorders
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Apr 11, 2008 | Gemini PT-1000 II Turntable
97 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
