Question about Radio Shack VGA PC Camera Webcam
MIC I installed the webcam driver as ordered, but I cannot get the mic to work. What can I do to make this happen
  • 1 more comment
  • Anonymous Feb 05, 2009
    windows found driver software but encountered an error while attemptig 2 install it
    the specified service ahs been marked 4 deletion
    windows found the driver software but encountered an error while attempting 2 install it
    mic will not work
    windows found driver software but encountered an error while trying 2 install it - mic does not work
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 05, 2009
Mic not working
1st You download Webcam Driver.
Download my Web Cam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Mar 14, 2014 | A4tech PK-635 Webcam
I cant install the webcam with mic
Steps for Installing Webcam with mic
1) Plug in the USB connector of the webcam into your PC's USB socket
2) Connect the MIC by pluging in the MIC connector to the RED audiio in socket provided at the back of your PC.
3) Install the webcam driver from the CD provided to you with the web cam
4) A new software must have been installed Click on the software's icon to start the web cam
Feb 27, 2011 | Radio Shack VGA PC Camera Webcam
Not working on msn, it was working before i installed software in order to get an icon so i could change the settings
Make sure Microsoft DirectX is installed and up to date
Set your webcam mic (if it has one as default)
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Aug 08, 2010 | Logitech Webcam
My mic is not working
Logitech QuickCam Communicate STX WebcamThis webcam does not have a built-in mic
To check
Plug in the webcam
TEST SPEAKERS
All available mics on your computer will show here
Right click on a mic and check the box to show disabled mics
Restart computer
Jul 31, 2010 | Logitech QuickCam Communicate STX Webcam
Terrible sound
You may need a headset if 'feedback' is a problem
Check your webcam mic is set as default.
TEST SPEAKERS
Restart computer
Configure your mic/ webcam to the chat program of your choice
May 24, 2010 | Logitech QuickCam Pro 9000 Web Cam
I just bought a live! cam voice and when i install the cd that it came with it says unable to install driver. so i went to their website and dl the driver n installed but now the problem is the mic doesnt...
Check your computer audio settings to make sure the webcam mic is set as 'default'
Plug in webcam
TEST SPEAKERS
Restart computer and configure to your chat program
Mar 18, 2010 | Creative Labs Live! Cam Voice Webcam
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Troubleshooting with ge webcam
Most likely you just need to unmute your mic. You can get to it by clicking on the Volume icon in your task bar (bottom right hand portion of your screen). You may need to click on Options and then Properties if you do not see the Mic control. Make sure there is a green checkmark on Mic and click ok. Then you should see the Mic settings on the panel. Make sure the mic is not muted.
May 03, 2007 | GE EasyCam Webcam
Radio Shack VGA PC Camera Webcam Logo
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
