posted by SCraig on Apr 06, 2008
My Bissell 1699 stopped straying from the floor nozzels but it will spray from the handheld nozzel. I noticed the red tank level indicator no longer rises when the tank is full (I am ordering a new tank). Would this keep the floor sprayers from working and still allow the hand sprayer to work? I hope to have the new tank shortly but I am curious to know if the pump could be bad ( I don't think so or the hand sprayer might not work).
Thanks,
Steve
Comment by SCraig, posted on Apr 28, 2008
Thank you very much for the tip. I had the unit apart at one point and noticed the heater so I will try your tip to see if it works for me. I will let you know the results.
Thanks,
Steve
Thanks,
Steve
I shot some air through the heater unit with my compressor (very lightly) and it did the trick. The unit is up and running again. Thank you very much for the advice!
Steve
Steve
Best Solution
posted on Apr 15, 2008
Usually when the hand tool works ok, then the heater inside the handle asm. is clogged. The water bypasses the heater when you use the hand tool. Other then that it could be a bad pump.
Comment by reddevil6, posted on Apr 28, 2008
If you use air to blow it out after it is unclogged, don't use too much pressure, if you do, you may blow the lid seal.
Rating Locked! (?) SCraig has rated this solution as FixYa!
Solution #2
posted on Apr 19, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I agree - just got done fixing 1 of these tonight. The heater plugs up and no spray. Easy Fix, the heater is in the handle and pretty easy to remove. then a straightened paper clip and a blast of air and you should be go to go.
Rating Locked! (?) SCraig has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Bissell 1699 ProHeat Clear View
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
