Question about HP PSC 1315 All-In-One InkJet Printer
Paper jam my printer/scanner 1315 every time i want to print the paper get stock and not print.
    Problem Solver:
  • 17 Answers
Ok i dont no if its and hp or what type you did not list sometimes when a paper jam is because the paper is not straight going in and check the back of the printer its a release that removes and there you find were jamed paper is check that try a differt type of paper if not go to the website of the printer and look at the suggestions
Posted on Apr 14, 2008
6ya staff
SOURCE:
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer jams
Check you paper and be sure it is dry. Sometimes if you are in any air condition areas the paper will get damp or if you run into this when the humidity level is high. Try storing your paper in a different room that is dry. Mine did the same thing after the temp changes outside. See if you can remember when it worked fine as to what time of the year it was. Did it work fine in the Winter for example and now in the summer it does not work.
Jun 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper jams with thicker stock paper
Your pickup tires on the printer may be worn, how many prints have you made on this printer. it may be time for a maint. kit.
May 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP 5610v states 'paper jam' and there isn't one - how to reset?
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
I'm going to go crazy!!!!!!!! HP PSC 1510xi All-in-one
Hi guys -
Well, I have to say - I have had HP printers for years and loved them - UNTIL I got an all-in-one! I have the 1315.
HP has NOT figured out the all-in-one printer package yet. There are software issues, and always always ink or paper issues. The scanner can be adjusted, but only so much, giving a really strange appearance to 3D items. Only paper items can scan well on it!
Overall, the best fix for an HP all-in-one is seriously to stop wasting time and ink and to get a different printer. I'd only had the 1315 for a month when I waived the white flag to wasting my time and effort. I bought a little cheap HP 3930, and it hasn't given me any trouble at all.
HP needs to work on the all in ones before continuing to market them. If you notice, there are new models constantly. That is because the figure out one issue, and instead of making a fix for it, stop support and put out a new printer instead, expecting everyone to just "upgrade" to the next new printer. Nope - not gonna happen.
What HP does have in its favor on printers, is that it is the only brand I've owned that didn't end up leaving "junk" on the paper - because of the printer cartridge heads, the prints are very crisp and clean, without overspray or dots.
Also very important on HP printers - be sure you get INKJET supplies if you bought an inkjet model. The papers are different, and many times, the laserjet supplies just won't go through their inkjets without jamming.
On the paper jam issues - while you cannot see a jam, it is somehow misreading the paper. Be sure you have the default paper size set correctly for what you are printing on. Also, take off the back and make sure there isn't just one piece of fuzzy paper back there. It doesn't take a full sheet of paper to give the paper jam error message - only a shred or slight piece where it doesn't belong. The track the printer heads run on is heavily greased and everything sticks to them! : (
I had to take the back off, used canned air to blow out the machine from the back, did it again from the front, uninstalled it and reinstalled it - that seemed to solve the paper jam issues.
I hope that might work for you.
Oct 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
44 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
