Question about Apple iPod MA446LL/A MP3 Player
Ipod not restoring
When the ipod is connected to itunes , itunes locks up and brings up an error 1318
  • Apple Master
  • 13,433 Answers
Uninstall itunes, then reinstall it if that doesnt solve the problem, continue with this troubleshooting guide
http://www.apple.com/support/ipod/five_rs/
if you need more assistance let me know, im here to help.
Posted on Apr 16, 2008
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
I locked my i pod nano and i forgot my passcode so now i can't us it i just got it, what do i do?
Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll still be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod).
To unlock it, connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using this method, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes.
3) Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
4) Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. Use restore option 4.
Oct 27, 2009 | Apple Mini I Pod -Blue System
How can i find out a code for a i pod
Oct 08, 2009 | Apple iPod nano
Locked i pod
Sep 17, 2009 | Apple iPod nano
Ipod will not restore
according to the apple website here is some help with the solution.
this is taken straight from apple.
Symptoms When restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected iPod, iPod mini, iPod shuffle, iPod nano, iTunes 7 for Windows, iTunes 7 for Mac, iTunes 8 for Mac, iTunes 8 for Windows
Resolution If you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
  • Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
  • If you use Windows, re-register .dll files as described in article iTunes displays -50 error message when syncing iPod on Windows XP
  • For Windows users, update or reinstall your Windows USB drivers.
May 22, 2009 | Apple iPod MA446LL/A MP3 Player
Have one nano 4gb red the problem is that i have erased all songs and when connected to pc says error1439
Hey here is an apple article about your error 1439....
  • Last Modified: October 01, 2008
  • Article: TS1372
  • Old Article: 304508
SymptomsWhen restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected
iTunes 7 for Mac, iTunes 7 for Windows, iPod nano, iPod shuffle, iPod mini, iPod, iTunes 8 for Windows, iTunes 8 for Mac
ResolutionIf you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
I hope this helps your issue. :) CHEERS
Apr 23, 2009 | Apple iPod nano
Cannot unlock 2gb i pod
Apr 02, 2009 | Apple iPod nano
Ipod
Seems its been locked for long enough.
You can remove the code by restoreing the ipod with itunes heres how
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Aug 17, 2008 | Apple iPod nano
Screen lock
Restore
For Windows:
Jun 19, 2008 | Apple iPod nano 3rd Generation
Help
well you have to perform restore to remove the lock
Restore
For Windows:
May 24, 2008 | Apple iPod nano 3rd Generation
Apple iPod MA446LL/A MP3 Player Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
