Question about NorStar T7316E Corded Phone
Voicemail Help please!!! When trying to access our voicemail system on our Norstar 7316e, (feature 983) it says "Inactive feature". Everything worked fine yesterday, how did the system get turned off, and how can I restart it?
    Problem Solver:
  • 5 Answers
Sounds like the voicemail is rebooting or was unpluged, make sure the call pilot is pluged in and the lights are on. i had a similar problem once and the power supply to the callpilot went bad. once i replaced it it came back up and worked fine.
Posted on Apr 17, 2008
I have a Nortel Norstar M73110 and I can't access the main greeting/main system control (Feature 983 stuff). Is there a way I can reset this password, or even hard reset the system?
Norstar M7310 features inactive
All features are inactive. I have done the following: 1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config). 2. Your display will read Feat code: and you will have options First and Exit. 3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next. 4. Press Test. Your options will read Remove and OK. Press Remove. 5. Once the feature code is removed, press Next to go to the next code. 6. Do this with all codes until your display reads None Registered 7. Release Next I am told to Restore connections to the voicemail ports from the KSU. Power the system back up. But I do not know how to do this. Please advise. Thank you!
Oct 04, 2017 | NorStar Lands Phones
Admin nortel i can't access the adminstrative programming. i enter feature 983 and it says "inactive feature". how can i fix it to where i can set up a new mailbox?
If you are getting inactive feature when entering feature 983 the phone system and voice mail unit are not communicating. This usually requires a power reset to clear. Or the voice mail unit is in trouble and a vendor needs to be called.
Aug 12, 2013 | NorStar T7316E Corded Phone
WHEN WE TRY TO ACCESS VOICEMAIL IT STATES INACTIVE FEATURE
NorStar (NTAB2666) Audio Conference - this is a conference unit.
You issues is with voice mail though.
Call a tech in since your system is down.
Aug 22, 2012 | NorStar (NTAB2666) Audio Conference
I am trying to access the administrative system for adding/changing voicemail boxes and auto attendant greetings on my Norstar Flash System. normally, i would hit feature 983, Log: 102 0000. but for...
Dial Feature 985
When the display changes to say SET something, dial 9
it'll prompt for a password, dial 73738767793
it'll ask if you want to reset the password, say YES
then you'll be able to login with feature 983 1020000
Apr 27, 2011 | NorStar Flash Voicemail Power Supply Only...
Feature Button
Sounds like the voicemail either is disconnected from the phone system or has lost power to the voicemail.Open the cover to the voicemail and see if there are any lights on in the system.If so then disconnect the power tho the voicemail for about 30 seconds. the voicemail could take up to 10 minutes to fully reboot.
Feb 26, 2010 | NorStar Meridian M7310 Phone
Hi there, Feature 983 gives me inactive feature message, can't forward calls, voice mail not working, etc. We had a short power outage the night before these symptoms began. Do I need to turn the power off...
Cycle the power on the voicemail system and that should solve the problem. If you still get the "Feature inactive" message, you may have to replace the voicemail power supply or get the voicemail system repaired.
Good Luck!
Dec 21, 2009 | NorStar Cics 6.1 & Call Pilot 100...
Norstar T7316 voicemail is somehow "inactive". Also the feature 983 is showing inactive so I cannot reset system..help
Sounds like the voicemail system is locked up and needs to be powered down and powered back up.
The voicemail, if it is a Call Pilot looks like a small gray box which looks like this in the photo: http://presstelegram.kaango.com/resources/img/itemimages/JUN/491159/LO10559_491159_06302009144332-large.jpg
You can unplug this unit for about 15 seconds, then plug it back in...
It will take about 5 minutes for the Call Pilot to re-boot, then you can dial FEATURE 9 8 3 to ensure that it has come back up.
Good Luck!
Sep 14, 2009 | NorStar T7208 Corded Phone
I have tried feature 981, 982, 983 etc. and I get the message "Inactive feature". What is the problem.
First make sure u r using Voicemail system which is either Star talk or call pilot.
If u r any one of this then only u can use F 981, 982 , 983 or 985. Its a feature code of voice mail.
If u r using either of this and still gettin inactive feature, then try with rebooting The Satr talk or call pilot i.e. switch off from mains wait for few mins and switch it back on.
After rebooting it will take 15-20 mins to boot up the system and after that u can use these feature.
Thanks.
Abhi
Jul 11, 2009 | NorStar T7316E Corded Phone
Also trying to initialize voicemail, says Feature 983 inactive
Feature 983 gives cess to System Administration; This Feature will ask for a Log:
Feature 981 Opens A Mailbox your mailbox # should consist of three digits. First what is the name of your mailbox system?
Jun 30, 2009 | NorStar M7324 Telephone
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
NorStar T7316E Corded Phone Logo
592 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
