Question about JVC HR-XVC18B DVD Player/VCR
Jvc thc60 5 disc dvd player
The insert for the bottom tray is stuck in the dvd player... How do I get it out? When we power the machine on or off, tray one shoots out.
4 Suggested Answers
SOURCE: Error message - incompatible disc
I spoke to JVC reference this problem and they suggested I returned it to them and they would check it. They collected the burner from my address checked it found there was a problem and gave me a new one.
Posted on Mar 12, 2008
SOURCE: DVD is stuck in Disc tray, will not open
I have a Phillips DVDR3390/37 and was getting a BLOCKED message. I found that by utilizing the slot on the bottom of DVD and moving the mechanism slightly to the left, it would open the DVD tray. The white plastic you see through the slot is part of the motor driven mechanism that raises the DVD disk up to the drive wheel that spins the DVD. The opening and raising actions are interconnected mechanically. I suspected the motor was going, so I unsoldered its black and red wires fom the small printed circuit board and removed it by also removing the two small screws on top. The board has a + mark and this is the red wire, remember which wires go where. (Might not be red and black.) I tested the motor with a flashlight battery and it seemed to run OK but didn't spin very long. This is a very small motor without a lot of reserve power. Removing it allowed me to oil the top bearing, the only one you can get at, as the bottom bearing is not open. You don't want oil all over the pulleys and the rubber band that rides in the pulleys and you have very little room to get the oil in under the plastic pulley. I used automatic transmission oil, a fine lubrican for a lot of things. This only takes about 1 drop of oil. If you get oil on the pulleys or belt, clean them with alcohol. This procedure fixed mine. Hope this helps.
Posted on Feb 22, 2009
SOURCE: JVC XV-N322 DVD player
Dear friend,
It is a software problem.Reflash ur dvd player.
Posted on Mar 29, 2009
I have a new samsung bd-f5700 player and tray won't open. Tried using the remote to open & the panel on top of player to open. Nothing works.
First, try resetting your player. Unplug it from wall for at least 1 full minute, then plug it back in. If eject function (remote or top panel) still doesn't work:
MOST DVD players (including every one I have ever worked on or owned) have a tiny manual eject pinhole located close to the tray. You may have to gently open the flip door to see it. It is usually to the right of the disc slot, but could be underneath or elsewhere close by (use a flashlight, it can be hard to see). Carefully insert a straightened paper clip in the pinhole to eject the disc. (It shouldn't matter if machine is on, but for safety I usually do this with the machine OFF and unplugged).
see http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html
or
http://www.ehow.com/how_2036594_fix-dvd-player.html
and http://www.ehow.com/how_6330619_retrieve-jammed-cd-dvd-player.html
If above fails, your only recourse is likely the disassembly of the machine (search "dvd disc stuck" on Google or YouTube), or taking your machine to a repair person. Best of luck to you.
Jun 23, 2014 | Samsung BD-F5700 Blu-ray Player
Dvd stuck in home 7-cd/dvd changer
So you want to remove the disc without damaging the disc? so its ok to damage the player.
Put a cushion on the floor, put player on it.
Use a strong pair of pliers to crush and bend all the plastic parts of the loader near the disc, shake the player so that the disc falls onto the cushion.
Dec 21, 2013 | JVC Audio Players & Recorders
I insert a movie from the video store in the dvd player Zenith DVC2550.It got stuck in back and turn table was rotating without picking up the disc. I had open cover to remove the disc. I manage to close...
It sounds like you jammed the door gear which must be closed prior to playback. You can try to take the cover off again and cycle the insert mechanism but if you put much force on it the machine may be destroyed...
May 05, 2011 | Zenith Televison & Video
Tray is lock
Try inserting a pin through the hole beneath the pray. Push the eject button and then insert. If you can't find such a hole, push the eject button and tap hard on the top of the tray twice or thrice. If it is not still working, check for any loose connection.
Apr 20, 2010 | JVC XV-N212 DVD Player
Cannot insert disc
If the problem is with the tray of the player, there will be a small hole at the front panel near the tray. You just need to put a pin into that hole, the tray will come out if it is stuck inside.
Thanks
Aug 09, 2009 | Sony DVP-CX995V Multi-disc DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
DVD jammed in tray
Should be a small hole in the front new the drawer. Stick the end of a paperclip into it and the drawer should open. Power off, of course.
Feb 26, 2009 | Televison & Video
TT320 DOESN'T WORK
SIMPLE....THE TRUTECH WENT IN THE TRASH AND I BOUGHT A NEW DVD PLAYER.....END OF STORY!
Jul 07, 2008 | TruTech TT320
Not recognizing any DVD inserted on my DVD player
dust in lens mean dvd does read! clean the lens with disc cleaner! some problem comes again mean you want to change the lens!
Jul 01, 2008 | JVC XV-S300 DVD Player
JVC HR-XVC18B DVD Player/VCR Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
