Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
SCREEN HAS COMPLETELY GONE
Opened the slide this morning and the screen simply lights up with lots of lines of colour - completely unreadable. I've switched it on and off, removed the battery and replaced it with no result. You can still manually make and receive calls but there is no way to access any information on the phone.
  • 818 Answers
You must replace the screen, prove this
Does the device have power? If so, reconnect to Motorola Software Update and perform another software update. If the device still does not power up, simultaneously press and hold the *-#-Power keys until the screen lights up. Connect to Motorola Software Update and follow the prompts display
Sergio
Posted on Apr 06, 2008
Hi there, my six year old dell latitude D800 lcd goes dark (not completely, but unreadable); (first brightness was jumping down and up). Two years ago I had such problem and solved by replacing the lcd...
Sorry to hear that, Paul. As far as notebooks displays go, the light behind the screen is the part most likely to go out. It generally does just that: it just goes out, though the screen itself works (the LCD is still generating a picture, which you said you can still see). Whether you run it dim or bright doesn't play much of a role.
Another inverter replacement is probably needed here, with the light itself (what the inverter is powering) an somewhat less likely explanation. In any case, the notebook will have to be opened up to do the work, where is where a lot of the cost comes from (unless you or a friend is doing the work for you).
Aug 08, 2011 | Dell Latitude D800 Notebook
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
Mar 01, 2011 | Amazon Kindle Wireless Reading Device
Hi I have a Panasonic LCD TX-32LXD there appears to be a line across the screen. It is about 1" 1/2 wide. but is completely see through and depending on what colours are on the screen depends how bad it...
Hi There,
Try restore the tv to factory state. It could be a burn in from a tv station you always watch eg. Some lcd will have a non burn in function, What that means simply is if you watch mtv all the time it will leave the mtv sign in the corner as its burned into the tv. Depends on how old the tv is restore and see what happens from there, other than that get an engineer or replace it if its still under warrenty....Hope this helps
Nov 17, 2009 | Panasonic TX-32LXD1 32 in. LCD Television
My girlfriend's nokia cell phone all of a sudden yesterday made a odd chiming noise and when she opened it up the screen she had was completly backwords for a few moments and then it went blank...can see...
If its a flip or slide handset, then the flex ribbon is damaged, this will need to be changed...
Sliding and flip phones have a thin ribbon, which connects the phones screen and any buttons that are at the top to the phones main PCB... A damaged one of these can cause anything from no display at all, white screen, fuzzy colours, rotated screen, dodgy bits, non functioning buttons and lots of other things.
Depending on your model you may be able to get a ribbon from somewhere like ebay and fit it yourself, some are more awkward than others, there should be a guide available somewhere, however it does depend on which phone it actually is :)
May 08, 2009 | Nokia N70 Cellular Phone
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
