I can't connect to the internet on my laptop unless I use my power cord. If I only use my battery I can't connect
    President:
  • 2,351 Answers
Hi klauzon2, you're laptop battery may not be able to hold a high enough charge. It's time to replace your battery.
Mike
Posted on Apr 06, 2008
Laptop will not power on.
If all connections are sound, then you have an internal problem with the laptop. All laptops have a soldered in fuse and it may be that this is stopping it from powering up. get it checked out as unless you know about electronics there is little you can do.
Mar 06, 2015 | Computers & Internet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Good mrning. The battery of my Compaq presarioCQ40-310AU is not charging when the laptop is in use, unless it is turned off.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 27, 2011 | Compaq Computers & Internet
Hi My daughter droped the battrey off her notbook and now she cant get on the internet, but its detected the wireless conection
there is no problem with the battery in terms of the connection. Battery only supplies power to turn on the laptop. if the battery has malfunctioned and wasn't able to turn on your laptop, you can use your laptop's power cord.
the issue here, is that you can connect to the internet. all she needs to do, is go to Network Connections, chose the wireless connection, clicked Properties, scrolled down to Internet Protocol (TCP/IP), go to Properties and changed the setting to 'Obtain an IP address automatically' then applied the changes.
Feb 20, 2011 | Advent Netbook
Replaced battery 2 months agoon HP zd7010 when I kept getting low battery/cannot charge/must shut down. If I removed battery and was connected to power cord, the laptop would boot/work. Now getting same...
know one here can answer any of that.
if the power pack is good, 19vdc in to the mobo then its GOOD>
if not not.
if the battery is bad, it can cause a dead system. shorted batteries do that, so leave it out. and run on the power pack
why not do that?
lets say battery out it still fails..
so the power pack is bad or the jack on PC is bad.
ive seen cloned battery packs from china fail in 1week
many. if you watch the news ,some catch fire, and lots of recalles.
even hp.com has recalls.... for this... as do all makers....
Batteries by there nature are problematic, for 100 years now...
whats the point there? use HP packs?
why not have 2 batteries , so when one fails the other yells
see I WORK>?
Mar 23, 2017 | HP Pavilion zd7010us PC Notebook
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Battery not charging.
I have the same problem at times. The life of laptop batteries is short if you are always connected to the internet. To save battery power / to increase the life of your battery overall and during each use, disable the internet when you are not using it.
Click on your "Local Area Connection Status", which is usually represented as an icon in the task bar menu at the bottom (blue bar) of your screen. Open that up and then click "disable" whenever you are not using the internet.
Unfortunately, at this point you might need a new battery though.
I hope this helps!
Sincerely, CBR2009
Aug 01, 2009 | HP Pavilion dv6000z Notebook
My laptop will not turn on. i push the power button and the lights flash on like it is getting ready to work and then they just go off.
A problem like this is often a power problem. If your battery is almost dead and you don't have a good power connection, the laptop might attempt to come on but then quickly shut down again. You should check all of the power cord connections. Is it connected well in the back of the laptop and at the wall? Some power cords also come apart in the middle, so you should check there, too. Also, are you actually plugged in to a live outlet? If it is a surge protector, the power switch might be off.
Hopefully your problem is this simple. If not, you probably have some sort of hardware failure and will need to have a shop diagnose the problem.
Mar 06, 2009 | Dell Latitude C610 Notebook
Problem with cable internet connection
you must have the wireless adapter and the lan adapter set to turn off when you are on battery power to reserve the battery, click on the battery icon in the taskbar and check the power settings or use empower Acer Epower management and turn them both on.
Sep 24, 2008 | Acer Aspire 5570-2758 Notebook
Keep getting disonnected from internet when using laptop power cord
weird problem you got there huh, just try to reinstall the wireless or built in lan card driver, is the power adapter near the lan cable outlet? maybe its just loose, try to use wireless connection in the internet
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
