The disk drives don't work!!
Hello i have a DELL dimension 1100 computer.It does'nt recognize my 2 disk drives. 1 cd-rom. 1 dvd-rom. Please help me fix it!
  • mrkennx6 Apr 06, 2008
    when i re-boot i stiil get the error message disk 0 not found..disk 1 not found.......kenn
  • William Rodriguez
    William Rodriguez May 11, 2010
    How old is the system? Is it still under warranty? Also, did you put these drives in yourself, or did they come with the system? If your system is still under warranty, contact Dell and they should be willing to fix it for you.
  • 57 Answers
  • Check your jumpers on the drives as tkw said.
  • Check your cable for any VISIBLE breaks (for some reason, some OEMs cut one of the wires on some IDE cables, which keeps the cable from running both drives, I don't know the logic behind it, but they still do it.
  • Try going into the BIOS and using failsafe settings.
  • Make sure all power cables are plugged in properly
  • Make sure your power supply is powerful enough to run all your hardware.
  • If none of the above worked, there is a chance the motherboard might be bad. But don't toss it yet. There are probably still one or two things you can do (just not any that I can think of/know).
Posted on Apr 06, 2008
  • 2,351 Answers
Hi mrkennx6, did you install windows Vista? If that's a yes try updating your windows through windows update. (Vista may have posted a fix for this issue).
If your not running Vista than try this.
1. Shut down your PC & unplug the power cord from the PC.
2. While facing the PC & looking at the front og the PC, remove the left side panel of the case. (Click the link to learn how to remove your computer cover).
3. Remove the power cable from the back of each cdrom drive.
Shown here at this link.
4. Re-connect your power cord & start your PC. Allow windows to finish loading. When it has finished, click the start button & shut down the PC.
5. Unplug your power cord from the PC.
6. Re-connect the power cords to your cdrom drives.
7. Close your case & re-connect the power cord to PC.
8. Power up PC & allow windows to load.
(Windows will re-install the needed drivers for your cdrom drives).
Good Luck!
If I can be of more service, just ask.
  • Mike Peluso
    Mike Peluso Apr 06, 2008
    Vista does see your CDROM drives but does not know what to do with them. You & thousands of other Vista users have a common problem. Some fix's work some do not & some gain their drives all by it's self just to loose it on the next boot up.
    So give this a try.
    You need to edit your registry.
    Click the Start button, click run, type in the run window regedit than click OK
    Close any opend Keys. Open HKEY_LOCAL_MACHINE than open SYSTEM next open CURRENTCONTROLSET than open CONTROL than open CLASS & find
    {4D36E965-E325-11CE-BFC1-08002BE10318} listed in the right half of the window right click on LOWERFILTERS & left click delete, then right click on UPPERFILTERS & left click delete.
    Exit the registry, and reboot the PC
    If these are in your registry. Lastly you can try looking through this link.
    Stumped by Vista-again.......
  • Mike Peluso
    Hi kenn, the error message disk 0 not found & disk 1 not found can be addressed in you're BIOS. Enter your bios, at the main menu check you're drives listing. I haven't been able to find the manual that show's you're bios settings. I do have you're manual, it just does not show bios functions. So I'll suggest by ear.
    In the main menu you'll find the clock time settings. You should also have you're drives listed (CDROM & hard drives).
    There should be a Primary Master drive & Primary Slave drive. (Usually the drive's S/N is listed too).
    (Ex: ST3250AS), this is a Seagate hard drive). Yours will be different. These listed drives should be you're hard drives. (If you have two drives connected).
    Next / under the Primary drives is the Secondary drive. (These should be you're CDROM drives). They should be listed as Secondary Master (name of cdrom drive) & Secondary Slave (name of cdrom drive). Are the names of listed drives correct?
    If the cdrom drive is listed incorrectly (not in correct order), than check you're cabling to your cdrom drives & double check the jumper on the cdrom drive is set to the correct setting. The carom drive at the end of the data cable should have the jumper set to Master & the next carom should be connected to the next connector in line & the jumper set to slave. (Correct this if not set right).
    Go to Boot section of your bios. Make sure your boot order is correct. First boot device should be floppy drive (if you have one connected). Or to first carom (carom who's jumper is set to master).
    While inside you're case please double check all data cables & power cables for a good connection, even if that means re-moving & re-connecting the data cable & power cables.
    Everything else is left up to VISTA. The OS supplies the driver for carom drives & USB's. If Vista does not see your cdrom devices it's not you're fault or you're hardware.
    It's Vista plain & simple.
    Best of luck Kenn!
  • 349 Answers
Ensure that , if they are IDE drives ,and they are connected on the same data ribbon as another drive ,that they are set up as a slave drive, via the jumper settings on the rear of the drive,
if both are on the one ribbon, setup one as the master and one as a slave drive.
good luck & please rate my efforts
Using Windows Vista on Dell Dimension Desktop: Windows Explorer does not show a DVD drive. The eject-close button does not extend or retract the disk tray. I have opened the tray manually with a...
try method 5 listed on this site:
May 22, 2017 | Dell Dimension E521 PC Desktop
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
My drive wont read or anything
Go here:
Select what operating system you have (xp or vista) then scroll down to where it says "CD/DVD" and choose your specific cd-rom drive model.
Download the firmware and run it. It should function after that.
(Also if you don't know your Cd-Rom drive model, right click on My Computer> Properties> Hardware Tab> Device Manager> Scroll down to DVD/CD-ROM drives and check out the model number.) Hope this helps! :)
May 28, 2009 | Dell Dimension 1100 PC Desktop
CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Jan 30, 2009 | Dell Inspiron 6400 Notebook
Will not recognize dvd rom
Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
What are your computers specs?
Jan 02, 2009 | Dell Dimension 2400 PC Desktop
Cd rom drive
Please use the Cd/Dvd Drive with the following specification:
CD-ROM/DVD-ROM/Disk drive
8X max DVD+/-RW Drive with DVD+R double layer write capability
16X DVD-ROM drive, 16X/10X/40X CD-RW drive
Sep 20, 2008 | Dell Dimension 8200 PC Desktop
Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Blue screen
According to the Microsoft Help and Support
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your CD-ROM is failing or is not supported.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue: 1. Make sure that your Windows 2000 CD-ROM is clean and is not scratched. 2. If you have more than one CD-ROM drive, run Windows 2000 Setup from the other drive. 3. If these steps do not resolve the issue, you may have to replace your CD-ROM drive.
Jul 04, 2008 | Dell Dimension 1100 PC Desktop
DVD/CD-RW Driver
I see this problem quite often. Microsoft has a guide that will fix the issue.
Click HERE
Jun 06, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
