Question about RCA HD61W66 61" Projection HDTV
RCA HDTV Auto Convergence
The Auto convergence works, then does not work. Works again after several trials, then does not work. Intermittent problem. TV is not even two years old, and have had this problem about 5 to 6 times, now.
  • RCA Master
  • 8,617 Answers
That model has digital convergence . It could be solder related or you may be needing a new convergence module in the near future. www.partstore.com may have the module in stock.
Posted on Apr 06, 2008
I have a rca HD61W66.. and the auto convergence is not working and the red is going way out of line when i am converging it..
Thats almost always caused by the Convergence power board. You can get the convergence power board PSDF-240 which fits your model from www.tvrepairworld.com
Jun 24, 2011 | RCA HD61W66 61" Projection HDTV
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Color problems.red turns to brown while watching programs
chech you boards to see if you have any loose soldering connections that is what my rca was doing and it had blown my fuse replaced it and did the soldering and works like new...
Apr 17, 2010 | RCA HD52W59 HDTV Projection Television
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
My rca 52" rear projection HDtv continues to need autoconvergence
The convergance board or faulty capacitor will have to be replaced.
Jul 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The auto convergence no longer works. The crosses
The common covergence problem with these sets is a blown solder in fuse beside the flyback transformer. It blows due to bad solder connections on the transformer itself.
Jul 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
you need to have the conversion chips replaced , this is a pretty common repair and i would say it is definately worth the fix, some repair shops will come and fix it within a half hour to an hour depending on the difficulty in taking out the old part and or putting in the new
Oct 07, 2008 | RCA HD52W59 HDTV Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA HD61W66 61" Projection HDTV Logo
869 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
