Question about Philips 42PFL5332D 42 in. LCD Television
Turns off at least once a week the TV turnes itself off without warning. i just turn it back on and it seems fine. but why does it just turn offin the first place?
  • Anonymous Jul 19, 2008
    This is scarey..it keeps turning on by itself..I have had it less than week....any ideas?
I have a 42 LCD Philipps TV (42PLF5332D) which is less then two years old. Last week while watching tv, the screen started to screamble and then went black. However, we do have volume and we can still manipulate the tv presets. Do you have any suggestions to what the problem is? And if so, is it worth repairing?
Posted on Oct 26, 2008
  • 138 Answers
Check the software and if it is not EJ30U_0.101.0.0 go to www.usasupport.com and put the firmware onto a USB stick. It will give you all the instruction on how to do it. If the set still turns off the problem is the SSB. Contact Philips @1-888-744-5477 and have your receipt to make sure the unit is under warranty and they will have a tech come out and fix the set.
Posted on Aug 20, 2008
My Mitsubishi WD 82838 TV turns off by itself without warning.
An update can cause issues
Most of these sets have two different resets done with the remote--the soft one on most but not all is with set on: Menu, 1,2,3 enter.
I am not speaking about the reset button on the set if it has that but a remote reset with Mitsubishi remote.
The hard reset (everything back to factory) uses a 4 digit number code
see if 1,2,3 helps or not---I doubt once upgrade done it will be easy to go back---Mitsubishi used to mail out a upgrade---seen more than a few sets with suddenly new issues after the upgrade.
Mar 30, 2012 | Mitsubishi WD-82838 DLP TV
My tv just turn's itself off and doesn't come back on for ages!!!
have a reputable shop check the "known to fail "power supply capacitors....they may not be filtering the power correctly to the main control board....that would be the next suspect
Jun 07, 2010 | Samsung LN32C450 32 in TV
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Intermittent power on/off
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Jul 01, 2008 | Panasonic CT-32G11 32" TV
Sharp TV switches to "input 2"
Mine does the exact same thing. I've had it for a few years no, and it just started doing this. It's so annoying. I don't think the weather has anything to do with it, though. It started switching itself just every once in a while, not it is almost every time I turn it on. Sometimes it takes an hour or so to start doing this, other times it's right away. Help!!
Jan 20, 2008 | Sharp 32C-240 32" TV
Jonesdavro@yahoo.com
I have a Samsung rear projection tv, it used to turn itself off every 5 - 10 minutes for about an hour then it seemed to work ok. I removed the rear cover and cleaned the cooling fans, has worked fine since.
Warning! Don't do this unless you are competent with electrical devices.
Dec 01, 2007 | Televison & Video
Rca f27450 TV
It sound like your set have dryjoints
Oct 11, 2007 | RCA 32F531T 32" TV
Philips 42PFL5332D 42 in. LCD Television Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
