Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Stacked Washer / Dryer not drining
Some water stays in the washer and smells awfull.....ant the door gets locked after finishing the cycle...
  • 869 Answers
Water pump is clogged.
Posted on May 26, 2008
SOURCE:
I have a code door locked in my WCVH6800J2WW
Poss able sensor problem. When the sensors go it stays locked indicating water inside, even though it is empty.
Oct 15, 2013 | General Electric WPDH8800J Front Load...
Frigidaire washer does not drain
Remove the drain hose from sink Unplug machine Safety 1st....put hose over bucket should gravity drain next take out the filter if its got one bottom /right hand side of machine clean...if not locate drain pump and remove blockage...kids sock maybe? Door may reset after water has been removed and unplugged .Good luck
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Hi, We just moved into
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Jan 01, 2011 | Washing Machines
The washer always seems to have water trapped someplace...when I turn the drum after a load has finished I can hear the water moving around. Now I've noticed a sour smell. Also sometimes at the end of a...
There is a solution inside the inner tub cover that helps serve as a balancing aid during the spin cycle. It is a normal sound on the washer. There is not a problem.
Jul 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
