Question about Refrigerators
Maytag refrigerator model #MFD2561HEW, 2 years old, suddenly stopped cooling. Digital read out in fridge is currently reading 65 degrees
  • 4 more comments
  • Anonymous Sep 04, 2008
    Maytag french door model #mfd2561hew only 2 years old! The refrigerator quit cooling but freezer still works. I tried cleaning the coils and unplugging it to reset it.
  • erik wagner
    erik wagner Dec 03, 2008
    I have the same problem. What did you find that was wrong?
  • pazpeitia Dec 25, 2008
    my maytag mfd2561hew is warm in the refrigerator and perfect in the freezer
  • awriffee Jan 11, 2009
    my fridge is warming up, 60 degrees fridge, 29 freezer
  • lumpyccc Feb 20, 2009
    Same model, same problem. Freezer works fine, refrigerator does not work.
  • Anonymous Apr 13, 2009
    Refrigerator is at 66 degrees and Freezer is working fine (temp -6).
There is a fan in the back of the freezer(my was made in Korea) that blows air up to the fridge. I had a service tech replace mine but I would do it myself if it happened again. Its not hard to get to and is easy to replace.
Posted on Aug 17, 2010
Show me a diagram of ice water system for maytag
Posted on Apr 06, 2008
Maytag refrigerator about 6 years old. side by side. Freezer is working perfectly but the refrigerator side doesn't get cold enough.
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 30, 2010 | Maytag Refrigerators
My refrigerator won't cool (freezer still working)
The temp sensor is the most likely cause of this problem. However, you have other possible options that you can test and check:
likely the problem with your fridge is a bad dumper control. This is a part which operates with the air flow from the freezer into the fresh food compartment.
The dumper control is located in the in the upper left corner in the fresh food compartment.
Sep 21, 2009 | Maytag MFD2561HE Bottom Freezer French...
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Your damper and controls are on this diagram.
Jul 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer suddenly defrosted!
sounds like you may have one that's in the maytag recall refrigerator and see if yours is one of repair.
Jun 12, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Fridge not cold enough
-Did you increase the temperature control knob to the higher number ?
-If not then do so. Increase to higher see what it'll do.
-If you already did to any number but still not cold then a New One
Good luck
Dec 19, 2017 | Samsung Refrigerators
Refrigerators Logo
1,120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
