Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Celsius CDW12 Dishwasher
Can you supply parts for this dishwasher? I need the handle/door opening mechanism which has broken and there for won't open the door.
Ian Pelly
ianpelly@hotmail.com
  • 3 more comments
  • Anonymous May 10, 2008
    Same issue - door will not open. Can't locate any release mechanism. Can't find any information on the brand on the interweb.
    Any help/tips?
  • drmahes Jun 19, 2008
    After using the dishwasher 3 days ago, I can't open the door. It's stuck & opening mechanism won't budge. I don't want to use too much force & damage it. Any solutions for this?
    Thanks
  • Anonymous Sep 16, 2008
    The door won't open after a full cycle of the dishwasher is cmpleted. Cannot release door at all. we need to know how to fix this.
  • Anonymous May 10, 2009
    my problem is the same I require a door handle assembly for a cdw12
  • arosin r May 11, 2009
    I have the same problem. I require a door handle mechanism for a celsius cdw12
Thanks for your offer!!! I am happy to pay for the part I need or a solution to the problem; but I am not going to pay for you to tell me you can't help me.
Ian
Posted on Apr 08, 2008
Phone 1300767041 they will fax repir manual
Posted on Feb 17, 2009
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
Dishwasher door will not open
You will have to remove the mounting screws holding the dishwasher in place. Then pull the dishwasher out of the space a couple inches.
You can then activate the door catch from the top to open the dishwasher.
Once you have it open,
You will have to open the control panel by removing the 6 screws across the top inside of the door. You can then examine the door latch assembly to find out what part is at fault.
Dec 20, 2009 | Maytag Dishwasher
Cdw12 instructions
I just moved into an apartment with a celsius cdw12 dishwasher and i don't have the manual Can anyone help me?
Nov 22, 2009 | Dishwashers
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Celsius deshwasher CDW12. Dial gets jammed on water inlet settings?
The Celcius dishwasher is owned by GAF. Their phone number in Australia is 1300 659 489. You could try them. Hope it works.
Mar 16, 2008 | Dishwashers
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
799 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
