Question about Kenmore 24902 Top Load Washer
Kenmore 80 series washing machine
Why won't my machine drain all water
  • 2 more comments
  • marrr Apr 08, 2008
    my washer spins well but it won't drain enough and my clothes are always full of water and soap. it is 10 yeaers old and is an inglis
  • scnurse Apr 22, 2008
    My washer has not been spinning all the water out for some time. Now, only a clicking noise is heard when I turn on the spin cycle.
  • Anonymous Apr 04, 2009
    spin cycle doesn't seem to rinse a lot of the water out.
  • hoagiejr1 Apr 04, 2009
    spin cycle does not drain enough water
  • 550 Answers
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Posted on Apr 30, 2008
Kenmore washer is unbalances with clothes or no clothes. It goes all over the place and I have to hold on to it.
Posted on Sep 03, 2011
I have Kenwore Series 80 Clothes Washer, Model # 110.26842694,Serial # CJ 3231197 and a couple of problems exist; as the timer reaches the rinse cyle the timer stops and needs to be set to the spin setting, during this period the water does not drain. Is there any suggestions for repair that can be advised. Thanks, Darius Caswell
Posted on Nov 21, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
SOURCE: i have a kenmore 80 heavy duty it will not spin washing machine
does it agitate?check your coupler.
Posted on Nov 14, 2008
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 113 Answers
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
Posted on Mar 03, 2009
  • 492 Answers
SOURCE: Kenmore 80 Series Heavy Duty washing machine
Unplug washer for 10 min to reset curcuit board. Then select the spin cycle. Selecting too many cycles in a short period of time can confuse the little brain in the board.
Posted on Apr 30, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Washer machine
i have E7 err
Jun 30, 2013 | Washing Machines
Kenmore 80 series 110.29882890 won't spin
That could be a lot of things. The first thing to check is the lid switch. You should be able to see where a tab goes into a slot from the lid to the main frame. You want us something like a screw driver to press that down while the machine is trying to spin and see if it kicks in. If not let me know and we can check some other things. How old is it?
Feb 20, 2013 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
1,351 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
