Question about SanDisk Sansa E280 MP3 Player
I can't delete my music!!! Please help.
I plugged my Sandisk sansa e280 up, I looked at the files and tried looking for the music file. For some reason there is none. I see a 'tmp' file but no music file.
-Is that the music file?
The problem is that the file is empty and my MP3 player has over 1300 songs on it.
-What is the 'tmp' file?
I synchronized my music on my player through either Rhapsody, which put crappy songs on my player, or Windows Media Player and it's almost like there is no music on it. I want a lot of music gone but the computer can't even detect the music so I can delete it. I want the music gone!(But not all of it.
-What should I do?
-Am I doing something wrong?
-Will I have to format it?
HELP ME!!!!!!!!!!!!!!!!!!
P.S: My MP3 player is a little over a year old.
  • Anonymous Apr 12, 2008
    i cant delete the music off my sansa 280r and my computer tells me that the cd that i just put on there is on but its not so can some one tell me plez
Go to My Computer -> right-click on the Sansa folder and go to "properties"
There you can check for errors, run the check, then go back and delete the files that are corrupted.
Posted on Apr 23, 2008
I'm having the same problem and trying to work through it. The problem is that your memory in the music section is corrupt. You may need to reformat. If I figure it out, I'll leave a note for others.
Apparently, this is a problem with this player. Not sure why. I've had this problem in the past and was able to fix it by disconnecting the battery and then reconnecting. But this time it's gone. I had a "bad track" message before it stopped.
Posted on Apr 12, 2008
2 Suggested Answers
poly_morph
  • 34 Answers
SOURCE: Sandisk Sansa
your in the wrong item. This is the sansa e250 which has different software. Besides the normal plug in and view hidden folders - then drag and drop, i cant really offer advice as im unfamilar with the fuze but if you repost your question under the fuze hopefully someone else can help you.
Posted on Jul 22, 2009
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Apr 27, 2009 | SanDisk Sansa E280 MP3 Player
Added music, but can't listen
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280.
(I could not delete/remove the files) I had to format the internal drive of the e280
and re-copy the files back on to the unit. Works great now. When formatting the device
use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that
you have backups.
Cheers
Nov 30, 2008 | SanDisk Sansa E280 MP3 Player
White Screen
I just dropped it on the ground till it turned off than i plugged it into my computer and it worked...>.> sorry if this sounds ridiculous :(
Sep 14, 2008 | SanDisk Sansa e260 MP3 Player
Bad Tracks
For the bad tracks go Under Settings, look for Mode or USB Mode. Put the unit in MSC (if that's available) or Rhapsody.
Connect it to the computer. See what driveletter it is :F: Sansa E280...G: Sansa E280... whatever it is.
Click Start/Run and type in chkdsk F:/f (or G: or whatever the letter is) . That will check and may fix the bad files.
I hope that helps
Please rate accordiingly
Thank you
Computerrep
Jun 18, 2008 | SanDisk Sansa E280 MP3 Player
Is there an easy way to delete all the music off of my mp3 player?
it says in the user manual that you have to hold down the power/menu button for about 15 seconds
Feb 19, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 froze
It is probably because you have folders inside of folders inside of folder... i just had the same problem and copied all the songs in a folder into the main folder IE
dont do this
sansa>music>artist>album>music file
do it like this
sansa>music>artist>file
Dec 04, 2007 | SanDisk Sansa E280 MP3 Player
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
Infinite folders and inability to play music
You need to reinstall the firmware, which can be found on Sansa's site. If this is not an option, which it likely is NOT, you need to send the device out via the MFG warranty, or just send it to the MFG. If you look into the files on this device, it has a VERY VERY bad history with performance on this site. I hope this helps! problem solved!
Aug 07, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
