Question about Sony SDM-HS74P/S 17" LCD Monitor
MY SONY SDM-HS74P
My screen stays on for a couple of minutes, then goes black. i am thinking it is the backlight inverter but i can't find this part or part# any where. can you help?
    Problem Solver:
  • 9 Answers
I had the same problem en replaced an black condensator, one of 1000uF, 10V or 16V, so if you replace it with a new one it's working again :)
Posted on Aug 31, 2009
  • 180 Answers
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Posted on Apr 08, 2008
SOURCE:
Monitor screen goes blank after few seconds, turn power off and back on, works for a few seconds and goes blank again. Any suggestions? connections are tight
It can be due to bad poweer supply caused by bad DC filter caps, bad backlights inverter circuits, bad lamps assembly. It will require in-depth trobleshooting.
http://s807.photobucket.com/albums/yy352/budm/SONY/
If you are going to DIY repair, please read below first.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Nov 03, 2011 | Sony SDM-HS74P/S 17" LCD Monitor
My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
Dec 13, 2009 | Sony SDM-HS74P/S 17" LCD Monitor
Monitor goes blank after a couple of seconds.
The problem can be the backlight inverter board or bad capacitors in the power supply section, I have seen bad soldering of the wires to the lamps are bad also.
Nov 05, 2009 | Sony SDM-HS74P 17" LCD Monitor
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
My monitor says "input ......" and then the screen flashes off.
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Sony SDM-HS74P/S 17" LCD Monitor Logo
1,037 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
