Having a problem trying to set up installation with disc
  • suzkibikeman Feb 26, 2009
    ok well i had to wipe the hard drive because it crashed and i went into the boot sequence to boot from the cdrom but it won't do it... it says no boot device available strike f1 or f2 to set up utility what should i do to get it to boot from cdrom to reinstall shitty windows?
    Genius:
  • 1,027 Answers
Enter the bios on start up and select in boot sequence to boot from cdrom then hard drive. save changes and exit,
some computers allow you to press F12 to change boot menu.
Posted on Apr 06, 2008
    Sergeant:
  • 349 Answers
You need to make sure that when the pc boot up it looks for the disc in the cd/dvd drive,you do this by going into the bios, pushing a key when the system is booting (sometimes Delete key) and selecting the drive that you wish the system to start with
eg,"D" drive to start the setup for windows, if "D" is your optical drive.
good luck, let me know if you need any other help
Terry
Mac installation disc hangs up
clean it, get a disc scratch remover kit,
Jan 12, 2014 | Apple Power Mac G5 Desktop
Error code F3-F100-0004
I suspect, you have been trying to restore to factory settings. This does appear to be a common problem with Toshiba Satellites. You should always make recovery discs if they are not supplied with the PC, a lesson you will now have learned.
You have two choices, you can either contact Toshiba and see if it is possible to purchase a set of Recovery Disks for you particular laptop. Or, you borrow (as you have already thought of) a Windows 7 OS disc. Keep in mind this disc must be the same version of Windows 7 that is written on your Product Key sticker. This will probably be stuck underneath the laptop. If you try to use a different version your product key will not work.
If you can get the discs from Toshiba this will save you the time and trouble of having to download and install all the drivers that you need for a clean install as they will be included on the discs. Hope this helps.
Jan 08, 2013 | Toshiba Computers & Internet
Laptop is turn off when trying to instal windows
have you got your windows disc in? also when you put disc in go to bios settings when you turn laptop on, press F2 and go to boot manager and select the laptop to boot from disc instead of it trying to boot from hardrive. and then it should go from there.
May 20, 2012 | HP Compaq 6715b Notebook
How to install Bentley MX Road
Make sure you are placing it correctly into the disc drive, then follow the on screen set up. If nothing comes up for the set up try locating the disc on your home menu. If your computer is not showing a disc on there then it might be a bad disc and you will have to get it replaced at no charge.
May 04, 2011 | Microsoft Windows Vista Home Basic for PC
I have Windows XP 2002 version. This software will not install on my computer. A disc shows up next to the pointer on the screen and then goes away. I tried start, Run method but it told me to install a...
Hi.
please try to insert the disk.
Activate start
Click Run
Give in the string - explorer
Click OK
Click This Computer
Click the drive for DVD - probably D: (can vari)
Click/Activate the file setup.exe placed on the disc.
This should work - this is a way of starting the installation if the disc is not set up to autorun.
Good luck
Regards
Mar 23, 2011 | Computers & Internet
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Windows Installation Disc..Toshiba Laptop
unfortunately when this happens it means your computer is suffering from a catastrophic system failure. In this case brought on by the hard reboot.
you can reorder a set of disk from www.toshiba.com. sorry it's not better news.
Sep 17, 2009 | Toshiba Satellite Pro L300 Notebook
Dell inspiron 7000
check whether the CD that you boot from is a "Bootable CD" . While burning an OS in a CD/DVD the option of "Make the disc Bootable" should be ticked on which makes the disc bootable with its boots records. The system will realise that the disc is a bootable one only if the disc has these boot files in it.  Try setting the boot sequence to Cd drive as first priority and dont forget to save the settings. If all your hardware componets are good, the above things will be the probabilities.
Mar 10, 2009 | Dell Inspiron 7000/7500
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
