Question about Zoom H4 Handy Recorder
Transfering music from the H4 handy recorder to the pc.
HI, I have a H4 recorder, I have installed the supplied disc, however I am unable to transfer music/recordings from the H4 to the PC. I have followed the instructions, and then found that the H4 is not included in the list of AUDIO under Sounds and Audio devices Properties, and I believe this may be the problem. How do I to add this to the the Sounds and Audio devices Properties?
Make the instalation of cubase LE that come when you buying the Zoom H4.When you instaled this,the driver H4 must appear in the sound/device properties.I hope you can solve
FF
Posted on May 08, 2008
SOURCE:
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Sep 16, 2010 | Zoom H4 Handy Recorder
Need english translation of zoom H4n handy recorder
You can download the English manual from:
http://www.zoom.co.jp/english/download/manual/english.php
Direct download link: http://www.zoom.co.jp/archive/English_Manual/E_H4.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks
Dec 29, 2009 | Zoom H4 Handy Recorder
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
Sep 02, 2017 | Zoom H4 Handy Recorder
Connect to PC does not work
You need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
May 06, 2009 | Zoom H4 Handy Recorder
Corrupted WAV file will not play or transfer to computer
yes!...
after try, try and try again... i have the solution now!
my english is very bad but i will try write good...
ok... i use one file recover (have many softs this type in internet...) i used this: R-Studio
try this and all will be ok!
good luck for yours!
Abimael - Lgm [email protected]
Dec 22, 2008 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Mac OS 10.4.11 does not recognize the Zoom H4 recorder
Mac OS 10.4 and higher require the Zoom H4 to be upgraded.
Go to  http://www.zoom.co.jp/english/download/software/h4.php#a  and choose the download to version 2.20 that applies to you. The instructions are there, but it is a little tricky. You must download the upgrade to your computer and then transfer it to your Zoom SD card.  To do that you need an SD card reader.  I used my digital camera. I took the SD card out of the zoom and put it in the digital camera. I Plugged the camera into the computer and when the SD card icon appeared on the desktop I dragged the "System Bin" file from the download to the zoom folder.  The rest of their instructions were pretty good.   Good Luck.
Sep 12, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
234 people viewed this question
Top Zoom Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
