Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon powershot A560
Lens won't extend all the way and getting lens error
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
SOURCE:
My brench of camara name Powershot SD1300is digital. when i turn on with my canon camara i see lens error will shut down outomatic restart camara.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 23, 2011 | Canon PowerShot A560 Digital Camera
My camera is a cannon power shot A560 and the lens wont open.How do i fixed it
Dec 30, 2010 | Canon PowerShot A560 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Powershot A1100 IS error lens restart camera
Well Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... You can follow the below link to know more -
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good Luck!!
Mar 27, 2010 | Canon PowerShot A560 Digital Camera
Canon A560 dropped.when the cam is on lens wont retract anymore
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens is stuck on my canon a560
Jan 04, 2009 | Canon PowerShot A560 Digital Camera
Powershot A560
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 15, 2008 | Canon PowerShot A560 Digital Camera
Canon PIXMA MP150 All-In-One InkJet Printer Logo
22 people viewed this question
Clive
Clive
old marine
old marine
Ekse
