Question about Audiofonics ADF-272 Car Speaker
I Got a Question
Ok i got tha ADF-272 12'' Sub. 1200 watts i bought a box that is for 2 12''s and wen i left he said to take tha ADF-272 w/ me so i didnt turn it down and it dont work One dude told me that it was under used and tha voice coil is messed up and sombody Else told me that it mite be Stuck that i would have to put Alot of wattage through it to get it to work... if the voice coil is messed up could i fix it ?? and could it be stuck or was he just messin w/ me??
  • 185 Answers
Ok well to anser the first one yes it can be re coned and i would not do it my self and to anser the secend one yes it can be froze and the reson for that is some one put to big of a amp on it and blew it causeing the woofer to freeze but if u want to have it reconed let me no and i will give u a number of a freind of mine
Posted on Apr 06, 2008
SOURCE:
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Nov 19, 2013 | Kicker Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
How should i wire my sub
if your amp has a bridge do nt bridge the subs just connect them normal planet audio subs usually dont have a high potential to withstand too much watts even if the subs say 1200 watts thats not true nwatts check the box the subs came in it will tell u true wattage it may say rms
May 24, 2010 | Nitro BMW-481 Car Audio Amplifier
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Orange juice in PS3
now its not completely broken the problem is that it has a malfunction from the orange juice cuz wen tha OJ(orange juice)fell on tha front of tha ps3 it probaply caused a wiring circuit to malfunction the system u can get it repaired not really. if u have a reseat u can call the people and they will probaply send a box so u can put tha ps3 in then send tha package where they tell u to send it then a package will come to u MAKESURE it comes cuz it will go 2 tha wrong hands lol then wen u get tha package u probaply notice its a new 1 or its just repaired now ur happy LLOOLL UR WELCOME
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Audiofonics ADF-272 Car Speaker Logo
93 people viewed this question
Top Audiofonics Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
