Question about GE Spacemaker JVM1640SJ Microwave Oven
DOOR INSTALLATION CAN YOU TELL ME HOW TO INSTALL MY MICROWAVE DOOR
  • NOVICE21 Apr 06, 2008
    I have a over the stove house hold speed cook oven, model#SCA1000DBB03 AND I WANT INSTALL A REPLACEMENT DOOR !
  • GE Master
  • 8,973 Answers
It's likely you'll have to pull it out of the wall. The installation instructions are critical to have when you do that.
If you don;t still have them, you can download them here: http://www.geappliances.com/service_and_support/literature/
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
Why has my Microwave stopped working? e130mh55gsa installed over stovetop. simple commands like cook for 1 minute, etc do not work anymore. manufactured January 2008. serial number 7g80305394. 12
Most commonly problem of Microwave Oven is the interlock switch in its door hinges. Since it is emitting microwave rays, it was built with such interlock switch to avoid exposure of human to said rays. So check first the continuity and functionality of said door switch.
Jan 10, 2015 | Microwave Ovens
Just had an Adora DVM7195 installed. Every time I try to cook anything, the control panel says "Insert Food". In other words, I cannot get it to cook anything.
try working the directions backwards start command then open door put mug in then use select then time then start
Jan 07, 2015 | In Microwave Ovens
How do i install a high point microwave door handle?
Look really good on inside of door. You should be able to remove the inner panel and then have access to bolts for the handle? If not... Epoxy is your best friend at this point! Good luck!
Feb 08, 2014 | Microwave Ovens
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a brand new Bosch microwave model HMV8051U It was installed for 1 day and the interior glass on the door shattered. What would cause this to happen?
It could be door alignment, damaged or chipped when installed, scratched and moisture got in the scratch and turned to steam under pressure or hit with something spinning around in the machine.
Almost anything.
Take it back and get it replaced.
Jan 03, 2011 | Bosch 800 HMB80 1000 Watts Microwave Oven
We have a relatively new (about 6 weeks old) GE OTR microwave--model is JVM1540SP1SS. Yesterday it started "running' even when there isn't any food in there and before we push any buttons. When the...
It sounds like a sticky door switch. There are several switches operated by the door latches to keep the oven from operating with the door open. It's possible someone got a little too rough when closing the door, which can cause misadjustment.
Since the oven is so new it will still be under warranty, though. Why not let GE fix it? You just need to tell them it's not working properly. First call the retailer where you purchased the oven. If they arranged installation they probably also handle service. Otherwise you can contact GE's customer service as instructed in your owner's manual to find out how to handle the repair.
Nov 28, 2010 | GE JVM1540SMSS Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
146 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
