Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Burner controls we installed a sealed cartridge #jga9150adp, and cannot lower the flame to simmer. Burners do reduce somewhat, but not enough to simmer.
  • jamesmoster Sep 29, 2008
    I Have the same problem, but no adjustment screw is visible by taking off the control.
  • help for JA Dec 08, 2008
    I have the same problem... this range has been problematic since we bought it! Had the electric control panel replaced... the inner glass of the door just broke... and have always had trouble with contolling the flame on the two left burners (grill replaced with burners).
    Yikes! I would NOT buy this range!!!
    President:
  • Jenn-Air Master
  • 2,651 Answers
If you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Posted on Apr 06, 2008
(Guru aborcass is basically right--I saw it done as described below. If you're like me, maybe it's better to hire someone.)
I spent the better part of a year calling Jenn-Air, our appliance dealer, etc. about what to do with the fact the, on our propane-converted range, these burners do not adjust. Jenn-Air admits nothing about this, and I found their parts department completely incompetent as well as rude.
FINALLY, hired an experienced appliance repair tech who adjusted the burner intensity (a set screw behind the dial on the RANGE, not on the module), and now it works fine. Since all our burners run hot on the range, I'm going to have him do the factory installed ones on his next visit. Hope this helps those who got as frustrated with the level of ignorance by the manufacturer as I did.
Posted on Feb 06, 2009
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
HOW DO YOU ADJUST SIMMER FLAME ON AN LP RANGE WITH SEALED BURNERS MODEL WFG374LV01 THE FLAME IS MUCH TOO HIGH WHEN SET LOW
The simmer adjustment is behind the knob for each burner.
Here are the instructions from the installation guide. Let me know if you have questions.
May 05, 2010 | Whirlpool Kitchen Ranges
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
Burner does not hold its flame on a Feather 442 stove
IF THE FLAME IS LIFTING OFF THE BURNER, THERE IS TOO MUCH AIR IN THE MIX. LOCATE THE END OF THE BURNER WHERE THE FUEL ENTERS THE BURNER. THERE SHOULD BE AN ADJUSTMENT HOOD THAT CAN BE MOVED TO PARTIALLY BLOCK THE AIR INTAKE. THIS WILL REDUCE THE AIR MIX AND SHOULD MINIMIZE THE FLAME LIFTING OFF THE BURNER.
ON SOME SEALED BURNER COOKTOPS, THE MANUFACTURER RECOMMENDS PLACING A PAN ON THE BURNER AFTER LIGHTING TO MINIMIZE FLAME LIFTING.
IF THE FLAME GOES OUT WHEN SET ON SIMMER,
THERE IS AN ADJUSTMENT SCREW IN THE SHAFT OF THE VALVE ON SOME MODELS. REMOVE THE KNOB TO GAIN ACCESS TO IT. YOU WILL HAVE TO OBTAIN A SMALL SHAFTED FLAT BLADE SCREWDRIVER TO MAKE THE ADJUSTMENT.
Mar 31, 2008 | Kitchen Ranges
Burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Mar 07, 2008 | Roper FGP325K Gas Kitchen Range
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
386 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
