Question about Toshiba 50H13 50" Rear Projection Television
Toshiba 50h13 image trembling
For the last month when you first turn the TV on the image is trembling.
We thought it might be the cable box, yet the other TV (winbook) is not doing that.
Help? Any fixes? Is this thing about to die on us?
I believe we bought it in 2004, give or take a year.
  • bpurks Mar 17, 2009
    I purchased the same tv in 02-03. Recently I have had wavy bars on the top of the screen. It would go away after a while. Now its whole screen and not even watchable. Can I fix it myself or do I need to call a tech?
    How much should the fix cost? Thanks for you help.
  • smartshortli May 11, 2010
    toshiba 42H83-picture shakes from side to side vary fast. can i fix it?
Q510 a.k.a. TA1360N(MOD) is bad. I know cause I bought this set.
Posted on Sep 17, 2008
  • Toshiba Master
  • 8,617 Answers
Something is not in tolerance in the deflection circuits if it is an up and down tremble its vertical deflection related and if its shakey from side to side its horizontal deflection. You will most likely need a skilled tech for this type of repair.
Posted on Apr 06, 2008
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Toshiba 50h13 wont turn on
Follow the voltage into the set, this kind of damage can be hard to find in any other way.
Nov 28, 2012 | Toshiba 50H13 50" Rear Projection...
Had the unit (46UX600U) for about 8 months with no problems. In the last couple of days the unit will seem to turn itself off and then back on. The green light never goes off though. This happened once...
If going through a cable box you may be loosing signal from time to time. Try playing a DVD to rule out the possibility that its your tv. Try replacing cable box, or add a cable amplifier. Hope this helps.
May 13, 2011 | Toshiba 46UX600U TV
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Hyper Module repair on 50H13
you need 2 check all the caps on hyper bwd.last one i did had 31 or 32 bad SM caps
change all----22mf---2.2mf---1mf---10mf
carefull not to lift traces
Sep 16, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 50h13 hyperboard
http://www.hdtvoice.com/voice/showpost.php?p=122387&postcount=7
Oct 16, 2007 | Toshiba 50H13 50" Rear Projection...
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Toshiba 50H13 50" Rear Projection Television Logo
365 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
