Question about Elektra S1C Espresso Machine
Elektra S1C: Not enough pressure
We have just started using our new machine, but the pressure does not seem to build up quite enough. The manual tells us we should wait till the pressure gauge reaches between the green and red marks, but it never quite reaches the green lower threshold. Is there a way to increase the prssure build up within the machine?
  • 137 Answers
You should look for pressure stat and look for calibration screw, than you turn it towards + to rise Little bit the temperature. Quoter of circle each test, until you get the desired temperature or pressure
Posted on Mar 31, 2009
Will only shoot one nail then I have to wait 10-15 seconds for it to reset. How can I fix it?
You may have an air supply problem. There needs to be an air regulator on the compressor so you can set the required air pressure for your nailer and project. You also need to verify the CMF output on your compressor is what your nailer calls for. If your compressor isn't large enough for the nailer, it will shoot one or two nails, the wait for pressure to build up . It will need to be high enough to operate per nailer requirements.
May 08, 2015 | Air Tools & Compressors
My john deere 2025r ran rough, then turned it off. Now it won't start. Cranks over fine, acts like it wants to start, but won't fire. Cleaned fuel filter, fuel lines, bled fuel lines. Pumped fuel through...
Did you bleed injectors? Pump primer pump up till you pressure, wait pumping crack a injector nut till you solid fuel. Than close. Go to next one, do the same thing.
Feb 28, 2015 | John Deere Garden
Have a Ryobi rpw 2400 petrol new never used yet, can't start it. If switch on O,nothing happen. If on 'I' pressure build up and block the motor .Any idea for solution?
As it's a new machine, check your operators manual it has a trouble shooting guide. But it sounds like the fuel maybe the problem, do not use old fuel as it deteriorates over time.
Dec 16, 2017 | Honda Karcher G2400HH-R Pressure Washer
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Apr 08, 2011 | Crock Pots & Slow Cookers
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a 2002 toyota corolla that likes to stall - taken the car to a mechanic twice in the last 6 months - they can't seem to find the problem - any suggestions or ideas?
when it stalls does it start right back up or do you have to wait awhile. if it stalls and wont start check for spark at the spark plugs and for fuel pressure. a common problem is the ignition module. it could even be a dirty throttle body if it is stalling at the stop sign then starts right back up. Check your air filter and the throttle body. If the throttle body has a bunch of carbon build up your car wont get enough air at idle. same will happen if you have a super dirty air filter. If the ignition module is bad the symtoms are usually that it wont start for a while till it cools down then will restart.
Oct 30, 2009 | 1993 Toyota Corolla
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Air pressure problem
I am having a similar problem.  Doesn't happen all the time, just sometimes.  My research has led me to believe it might be the vacuum breaker valve.  I am going to order a new one here:
I'll replace mine & post if it fixes it.
Good Luck
Sep 02, 2007 | ECM Giotto Espresso Machine
Elektra S1C Espresso Machine Logo
303 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
Shehu Pro
Shehu Pro
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
