paper jams right before it gets to fuser. I can open up front and pull the paper out and it has a little less than a wuarter of the image on the page.....pull out the paper and it jams again....then it printed fine and next time jammed again. It never even touches the fuser. It is a Kyocera Mita 4230. Thanks a lot!!
it could be lots of things but for starters check to see if the other paper sources cause the same problem. try using the bypass one sheet at a time at first. second, there is a sensor shortly after or around the drum unit, if it doesn't activate it within it's specified time it will stop the machine, causing a jam.
thirdly is may be the transfer/ seperation issue, there also a couple of transport belts that may not be turning. check everything at let know if those things solve it.
Hi, My name is Julio. I got an old EP2010 Copier and i used to use it till this morning I get the...
(More)
Hi, My name is Julio. I got an old EP2010 Copier and i used to use it till this morning I get the C00-00 code on the display every time I try make a copy. I did two copies this morning, then tried another copy and faile. Need immediate support
Error code P appears when switched on and goes out for 1 copy only when cancel button pressed.It...
(More)
Error code P appears when switched on and goes out for 1 copy only when cancel button pressed.It will then print 1 copy and reappear. How do I cure this problem?
