I am trying to set up my 4300 series all-in-one, it says plug in and select required language, but it goes to change cartridge straight away
    Problem Solver:
  • 11 Answers
When you installed the software, was the all-in-one already plugged in? Look at the documentation...some specify that you must install software FIRST....other software second. If you did it in the wrong order, go to start-settings-control panel-add/remove software, and remove the software....reboot.....then do it in the correct order.....
Posted on Apr 06, 2008
SOURCE:
I don't know the language of my Samsung SCX-4300 how to change it to english
Without knowing what the language is makes it very difficult to change it unless you have the exact same phone in the other hand to use as a reference. Your cell phone service provider can help you with this if the phone came from them.
May 25, 2012 | Samsung SCX-4216F All-In-One Laser Printer
My baby has changed the language on my text input and i cant change it back,, how do i do it?
Xperia X10
To set the phone language:
1. From the Home screen, find and tap Settings > Language & keyboard > Select locale.
2. Select an option.
Note: The chosen phone language is also the writing language, if not selecting a specific writing language.
To set the writing language:
1. From the Home screen, find and tap Settings > Language & keyboard > Default input > Writing languages.
Useful tip:
* To change the keyboard when you're in a field that requires text or numbers, touch and hold the text bar, then tap Input Method and select an option.
* To enter special characters, such as å, just touch and hold the corresponding letter, and select an option.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How can i change language in google chrome?
Click the wrench icon chrome_toolsmenu.gif on the browser toolbar. Select the "Under the Hood" tab at the top of the window
Select "Change font and language settings" Under "Web Content"fire_eater64.png
Select your language from the popup window, and press "Ok"
Then change your "Spell Checker Language" and "Google Chrome Language" from the drop down menus.
Press "Ok" followed by "Close"
You may be required to restart Google Chrome
Hope this helps :D
Mar 02, 2011 | Google Chrome
I want change language?
For changing the language
1) Press the Menu Key
2) Go to Settings > Phone Settings > General > Personalization > Langauge
3) Select the 'Phone Language' option and select the required language.
* You must need to install the required language packs before using this.
Feb 19, 2011 | Nokia 5320 XpressMusic Cellular Phone
I bought my hp photosmart c3183 from middle east but the cartridges 131 and 135 are not available in pakistan, instead hp 92 and 93 are used in pakistan for this printer. i installed 92 and 93 cartridges...
Have you reset the region from the menu?? To do so kindly follow the procedure below
The language and country/region setting determines which language the HP All-in-
One uses to display messages on the color graphics display. Usually, you set the
language and country/region when you first set up the HP All-in-One. However, you
can change the setting at any time by using the following procedure.
1. Press Setup.
2. Press 6, and then press 1.
Finish setup
This displays the Preferences menu, and then selects Set Language & Country/
Region.
A list of languages appears. Press or to scroll through the list of languages.
3. When your language is highlighted, press OK.
4. When prompted, press 1 for Yes or 2 for No.
The countries/regions for the selected language appear. Press or to scroll
through the list.
5. When the country/region you want to select is highlighted, press OK.
6. When prompted, press 1 for Yes or 2 for No.
If you require more assistance, feel free to reply to this post,
Thanks for asking FixYa!
Regards, Bilal
Feb 09, 2011 | HP Photosmart 3310 Printer
Change chinese language to english language on lg laptop xnotev1 series after recovery
Whilst running the restore programme, one is invited to select the required language.
It will probably be easier to run Recovery again and choose English Language.
Hope this helps
Dec 13, 2010 | Computers & Internet
When I click the print button, a fax window pops up, and it will only let me fax, and not print
In Windows Xp
Click on start and click on control panel
in control panel look at the top left and switch to classic view(unless your already in it,if ur in it then u'll see a lot of icons and not groups)double click the printers and faxes folder.
now look at the tow icons of your printer and one will say officejet 4300 series and one will say 4300 series fax.
right click the 4300 series and select set as default.
Now click on print if you still get the fax window select your printer icon in the drop down list and then the fax window will not popup.
IN VISTA
Click on the start button and in the start search box type "printers" and press the enter button.
In the printers window single left click the printer icon(4300 series,not 4300 series fax)
Then single right click the 4300 series icon and select set as default.
now close the window and try to print if u still get the fax popup then selet your printer icon in the drop down menu and it will print and not fax
Jun 25, 2009 | HP Officejet 4315 All-in-One Printer
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/[email protected]@@@[email protected]@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Open Questions:
43 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
