Question about Motorola Mobility RAZR V3
My phone got wet
Hey, My motorola V3 got wet on te weekend and after drying out once again turns on but doesnt regiter as havin a Sim card installed. Is there any way to fix this problem? or is it possibly to comehow retrieve the saved phone numbers which are on my phone?
  • andyrenee May 01, 2008
    my phone turned off and the screen doesn't work anymore but i need my contacts where can i go to get them on it
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and ahve them service the phone and reflash the main-board if that does not help then you need to replace the phone.
Posted on Apr 14, 2008
SOURCE:
I have a new motorola razr v3....bought to replace one dropped into the lake. New phone charged up and comes on but message says install sim card....sim card is in but apparently not recognised. What next?
Dismentel your cell and wash it with acetone solution by rubbing your old tooth brush and let it dry for half an hour and then assemble it and try again
Jun 09, 2010 | Motorola Mobility RAZR V3
My phone keeps saying unregistered sim card
Hey,
Take the battery out of the phone and locate the sim card. Remove the sim card and get an number 2 pencil with a good eraser and use the eraser on the gold contacts on the sim card lightly to clean up any corrision that built up on the contacts ( it will look black) . If that doesnt work go to your cell phone providers store your sim card got fried. they can set u one up for like $25
Aug 14, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
I have a Motorola W260G Tracfone and I'm getting a "Restricted Number - 34" message all of a sudden. What is this about?
Had a similar problem on my V170. Remove the battery and the sim card. Using a q-tip dampened (not dripping wet) with rubbing alcohol, clean the metallic side of the sim card and allow to air-dry, then wipe once more with a dry q-tip. Do the same for the metal terminals in the sim card slot if visible. Go ahead and clean the battery's contacts and the ones in the phone while you're there. Put it all back together and try again. This will fix most sim-card problems as long as there's no physical damage.
Good Luck
Jim
Aug 03, 2009 | Motorola Mobility TracFone® V170 Cellular...
Unlock subsidy code for my moto razr v3
you mobile need to be unlock so you need to take your phone to a mobile service center to have that done or try online at unlockitnow.com or mobile2mobile.net.
Oct 25, 2008 | Motorola Mobility RAZR V3
Inserting SIM card in Motorola V3C
Ahh! but there is a slot. Remove the battery and slide in the skinny sim card where you don't think there is space.....voila!
Feb 09, 2008 | Motorola Mobility RAZR V3
Insert SIM Card
you need to get a new main board.....or you can take it to a mobile store tech and have the phone fully service.
But the best solution would be to buy a need mobile....most time when a mobile gets wet......it's more of a 50/50 chance that it will work properly again.
Jan 06, 2008 | Motorola Mobility RAZR V3
Razor phone not reading sim card
Have you tried a different SIM to make sure that isn't the problem? I'd say 3 out of 4 times when the phone gets wet the other stuff works after it dries, but people constantly have problems with reading the SIM afterwards. Hopefully swapping the SIM card out will help, otherwise your only option is to have a repair shop fix it up for you.
Dec 19, 2007 | Motorola Mobility RAZR V3
Motorola razr got wet. has over 400 #s in it
Numbers are on the SIM card. It will work in another phone once dried out.
Dec 05, 2007 | Motorola Mobility RAZR V3
Neeh help with my motorola
There is problem in your sim card, try other sim card .,or contact your service provider
Nov 11, 2007 | Motorola Mobility RAZR V3
V3 got wet
sorry to say this but a wet phone is ruined. You will have to take it to a tech at your phone server. They will either repair it or you will have to get another one. Water and phones do not go together at all. Sux.
Aug 20, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
