Question about Samsung SlimFit TX-S3082WH 30" TV
Zapping sound when turn on
Whenever I turn on my Samsung slim fit tv, it makes this awful zapping noise. How can we make that stop?
  • 5 more comments
  • pxuk Apr 24, 2008
    Yeah ive got the same problem, 2days ago i was hearing it and now everytime i turn it on.
    the sound kills me......
  • Anonymous May 06, 2008
    me too, high pitched buzzing from the back.  It is killing me
  • Anonymous May 13, 2008
    same thing, started a month ago. Now I have white snowy lines running down the screen
  • Anonymous Jun 08, 2008
    no power tv wont turn on. is there a safty button on back of tv to reset it?
  • Anonymous Jun 14, 2008
    Blackout.... no power or light.... 2yo tv and this is the 2nd major breakdown. Help !
  • cobra5000 Aug 11, 2008
    my samsung slimfit tv is making a horrible high pitched noise, the video and audio are fine but this high pitched squealing noise is too much to bear. i called a service rep and he said it was common and there was a coil inside that needed to be replaced. he said it would be about $85.00 but they are on vacation for the next 3-4 weeks :(
  • Anonymous Sep 11, 2008
    this problem is from a transformer tray or some such thing, my tv was under warranty when this happened to me, I waited 3 mos. for a part that Samsung knew they didn't make anymore and I was given a 32 lcd as a warrenty replacement.
Same buzzing sound here...help!!!!!!!!!!!!!!
Posted on May 10, 2008
I can hear a zapping noise.the front green display is not lit.
Most of the time a zapping or crackling sound is a bad electrical connection. I would check the connections were the power from the source is connected to the oven.
Aug 18, 2015 | Smeg Ovens
Whirlpool (Old) dryer makes a zapping noise at the outlet. It will run, but there is no heat
Unplug the dryer, IMMEDIATELY.
Get a Pro to check for wiring shorts or heating elements that are, burned loose, touching or other wise going to ground...
What you are describing is a severe fire hazard if not corrected...
Feb 16, 2014 | Dryers
Motor mount buzzing
unplug the engine mount. you will never know the difference if its plugged in or unplugged.
Aug 03, 2017 | 2005 Nissan Maxima
Lennox air purifier zapping sound
This may be an electronic style air filter which causes a bug zapper noise when "zapping" dust. I was out doing some research myself on them which is how I came upon your question. It seems they need to be cleaned carefully; which I am seeking instructions for. Best of luck in your ventures! Do some research, they are expensive to repair if you break them in the process of trying to clean or remove them. This page did a decent job at explaining the why it zaps part. http://dhclimatecontrol.com/filter.htm
Jun 19, 2012 | Heating & Cooling
51MP392H/17 Makes Zapping sound on power up. No picture or sound. Has been reset/unplugged. When powering up makes a sound like a bug zapper for about 1/2 second. Power light stays on and I can hear the tv...
The Zapping sound you are referring to is most likely due to arcing of the flyback(high voltage transformer). It is strongly recommended that you do not turn on the tv and have a tech test the flyback and replace it. The FBT generates voltages of about 30000V and should not be handled by someone who has not worked on high voltage electronics before.
Feb 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Makes a zapping noise when you turn on the electronic air cleaner
If the the "zapping" noise you hear is intermitant (like a Bug Zapper) it's probably dust that the air cleaner is picking up from the household air. .If that's the case, there's nothing to worry about, it's doing it's job.
If the "zapping" sound is continuous, then the unit may need cleaning, as it may be clogged with dust & lint.
Feb 08, 2011 | Air Purifiers
Hi We have no picture and it is making like a zapping noise at rear of tv like electric zapping ta
Hi you probly have a high voltage parts crack /sometime its the high voltage from the fly back
to the yoke plug or its cracked device like the screen and focus adjustement module.
dont leave it pluged in the wall, unplug it could make dammage to other parts
hope that help you
Mar 17, 2010 | Televison & Video
Picture and sound gone
The Flyback Transformer is probably shorted to the core and shorted out the Horizontal Output Transistor. Changing both will probably fix your problem. Let me know if this helps.
Oct 14, 2008 | GE 25GT240 25" TV
Electrical zapping noise , tv turns off after starting
can you post a picture of it? It sounds like youre talking about a box capacitor.
Jun 17, 2008 | RCA D52W19 52" Rear Projection Television
Get a weird zapping noise
sounds like theres a short, most likely the flyback transformer
take in for service
Dec 05, 2007 | Zenith D52WLCD 52" Rear Projection...
Samsung SlimFit  TX-S3082WH 30" TV Logo
765 people viewed this question
Henry  Thomas
Henry Thomas
