Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Riding Mower Won't Shut Off
We have changed eveything on our mower as far as maintenance. The one thing it will not do is shut off when you put the throttle to slow and turn off the key. You have to pull out the choke to get it to shutoff and then it either makes a loud noise when it stops or emits blue smoke. What can be the problem.
    Champion:
  • 313 Answers
Check out www.smallengineadvisor.com for trouble shooting & repair.
Posted on Jun 12, 2008
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Gas keeps getting in with oil what do I do riding lawn mower
Happened to my Husky..Your mower is equipped with the EPA positive shutoff electrically operated valve on the bottom of the carb..it is designed to stop overflow of gas from the carb when the float sticks.. however when it fails the gas now flows back through the carb and into the cylinders and eventually filling up the crankcase and cylinders.. In stead of to the ground...You can replace it but eventually it will fail...the easiest and best fix is to put a easy to get to shut off valve between your tank and carb..When ever you shut your mower down for ANY reason turn off that valve before shutting it down..put mine on two years ago and hasn't failed me yet...Just need to remember never shut the mower down with out turning the gas flow off....NEVER....it may not fail but when you least expect it WALA oil in the gas...best is to shut the gas off and let it run for 20 seconds or so then shut the mower down..this assures no gas in the carb system cannot get into the oil...hope this helps pass it along to your friends as all newer motors are required to have them...good luck.
Apr 16, 2015 | Garden
Wire seat so mower doesn't shut off
Put a piece of wire hooped in plug the seat switch plugged in to. It not good to jumper out safety items.
May 03, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
When i dich in gage the cluch the motor will shatoff or in gage the mower it will shut off .and put it in gear it will shut off.
Check your seat switch. If the switch thinks no one is in the seat, it won't allow the mower to move or blades to turn.
Let me know,
Gary
May 29, 2011 | Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
What oil grade do I use in my 20hp huskavarna riding mower
use a good grade of automotive engine oil which is called 10w30 weight.
measure the amount of oil that you drain out so you will know approximately how much new oil to put in. then check your dip stick and adjust to get the exact amount of oil.
May 21, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
308 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
