Question about Dryers
Dryer wont start replace new swtich and new cord
  • 3,230 Answers
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Posted on Jan 26, 2011
Original xbox wont turn on
Try unplugging everything off and then back on. Also, swtiching the power cord, if not i know Videogame911.com fixes both the cord and console.
Mar 25, 2013 | Microsoft Xbox Console
No power to circular saw
Remove the part of the handle over the switch and have a multi meter handy. Plug the cord in and test for voltage where the cord goes into the switch. No power, replace the cord; power, go on. Have someone hold the swtich on and test for voltage coming out of the switch. No power, replace the swtich; no power, go on. Check the condition of the brushes and brush springs. They have to be in good contact with the armature to work properly. If the brushes are OK, you may have a problem with the armature or field. These are usually checked at a service center with equipment most people don't have. If you got this far and haven't found the problem, it may be better to get a new saw.
Aug 13, 2012 | Craftsman 13 Amp 714" Circular Saw
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
I just bouhgt a new battery for my gsxr 04, but still no lights on neutral position and wont start
make sure your safety swtichs are working i.e. the neutral swtich it's on the motor by the counter shafter
May 23, 2011 | 2008 Suzuki GSX-R 600
Door swtich not working how do we fix it
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 29, 2010 | Kenmore Dryers
Wont Run unless hold start switch
You most likely have a faulty motor centrifugal switch. This switch is engaged when the motor starts rotating. The switch itself could be faulty or the inertia-mechanism that activates the switch could be faulty. The inertia-mechanism usually has two small springs that pull it back into its resting position when the motor stops turning. I have found that the springs will sometimes break and produce the symptom you have described.
Below is a diagram of common centrifugal switches. The switch will be mounted on the end of the motor.
Jun 21, 2010 | Kenmore 63932 Electric Dryer
My dryer would not run when I pulled the knob to start. I took the power cord out of the wall outlet. When I replace the cord into the outlet and pulled the knob the outlet sparked.
you most likely have a loose wire inside that wall outlet. use an extension cord to plug your dryer into another outlet that you know works properly and see it your dryer will work on that power source. If it does, just replace the receptacle in that wall outlet. If the dryer still wont run, then you know you have a problem with the dryer itself. If that is the case get back and I can talk you through solving that problem also.
Oct 25, 2009 | Dryers
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
