Question about Panasonic SC-HT730 System
SC-HT730 Color problems
My home theater system has loss the proper colors, the intro image has change from Blue to Green and there is a lot of pink when the DVD's play. I have tried adjusting the picture under the Functions/Other Settings/Picture Mode/User/Picture Adjustment, it did help some but on the picture that is has
  • cmatheso Apr 06, 2008
    That's what was causing the problem, Thanks for your help, some times the simplest of solutions should be looked at first.
    Problem Solver:
  • 7 Answers
What kind of connection are you using? If you are using a component connection or a RGB connection this could be causing your problem check the leads and if so replace new leads.
Posted on Apr 06, 2008
6ya staff
SOURCE:
When i play dvd the picture is black and white
If you are using component cables red green blue amke sure they are all properly connected and secure. A misconnection will definately cause the picture to be black and white.
Mar 14, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
DVD and Menu screen color settings are not right. We recently had the local Bose store set up our Lifestyle 48 system and all was well but recently the screeen color, when in menu mode, has changed from...
Jason.... there seems to be a connectivity issue and i could not see any of your messages in the chat box.......
for reconnecting the unit... please refer to this link below
http://products.bose.com/pdf/customer_service/owners/ls18ii_ls28ii_ls38_ls48_install.pdf
the Surround speaker cables have orange RCA connectors at one end and speaker plugs
at the other end with L (left) or R (right) markings
Jul 31, 2010 | Bose Lifestyle 48 System
No color when playing DVD's on Sony DAV-HDX500.
What's different? The video connection type, maybe? If you're using Component cables (Red, Green, Blue) you might want to check their integrity.
Jul 01, 2010 | Sony DAV-HDX500 System
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
Green tint?
you have a bad video cable and its only allowing green and not red and blue, if changing the cable does not do the trick the you video controler in the dvd player or stereo has go bad, might try pluging dvd player into tv directly. that will help you determine if its the player or stereo. good luck
Jun 13, 2009 | Panasonic Audio Players & Recorders
When I play a dvd it is in black and white how do I get it to be in color
It is very likely that your connectors and cables are causing this problem. I am guessing you have component cables and one of them is either not connected, or that the connectors are not in the proper location (green to green, red to red, blue to blue) or that the cables are of different length. Similar problems occur with S-Video with bent pins and in some cases HDMI has some issues with dirt or that the connector isn't firmly seated.
Feb 24, 2009 | Panasonic REGION FREE SCHT700 5 Disc DVD...
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Connecting a sony home theater system
When a DVD is played on our Sony (surround sound) player there is a pink cast to any color segment. Old black and white footage is OK.
Sep 14, 2007 | Toshiba 42HL67 42 in. LCD Television
My TEAC PL-D2100 home theatre system, is not showing all natural colors in display since yesterday.
the red rca jack of the component output on your dvd player or the red input on the Avr component input is not plugged in properly ( loose ) or the the component monitor out to the tv may be loose. there is also possablity of cable cut. check it with another component cable or interchange the red to green to find if the problem perssts ,... to ascertian weather it is the cable.. this info should solve your prob.
Jun 30, 2007 | Teac PLD-2200 System
On screen color
1.Check your component video connection,and see if you are any cable that is not connected properly(most commonly swamp between Pb-blue, Y-green.)
2. If the connection is correct FOR SURE,check your system menu under video connection or output and see if you have switch it to component video output.
Joe
Dec 11, 2006 | Panasonic REGION FREE SCHT700 5 Disc DVD...
Panasonic SC-HT730 System Logo
127 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
