Question about Sega Saturn Console
Sega Saturn Games will not boot, games show up as audio cds
I found a saturn i thought i had lost 10 years ago. everything works perfectly fine, it has not been modded and the laser is not stuck being hindered from reading the outside ring on the games (i took it apart to check). i put a game in, the system starts up perfectly fine, the screen goes into normal view, it says 'checking disc type' like usual, then it sticks in cd player mode and plays the audio tracks on the game cd. what in the world is going on?
  • 1 more comment
  • Anonymous Apr 17, 2008
    will not play game stuck at cd mode screen and will not play any tracks
  • Magitek85 Apr 30, 2008
    I have this same issue. Also everytime I start up the console it tells me to set the language and date/time.
  • nikclouthier May 13, 2008
    I also have this problerm, except i just got mine in the mail today from ebay, I paid for it because I had a really hard time to find one where I live...I went to boot up the game and the same thing happened....so if u guys or anyone can help please do so!!! and let me know
    Problem Solver:
  • 10 Answers
I know what's causing the problem--the spindle motor for the CD's doesn't spin fast enough to read the disc properly; this usually happens when the system gets hit too hard or is dropped. This causes games to recognized as audio CD's and also causes the tracks to play improperly (there will be complete silence when a track is played and possibly some static at the beginning and the cubes an the sides of the display will be distorted and blown up.IF THIS DOES NOT HAPPEN THEN DO NOT ATTEMPT THIS.)Before starting, make sure the system is plugged in, there's no controller connected, and the system is NOT hooked up to a tv. Okay, now this is where it gets complicated. first, take the top of the system off and locate the disc drive switch. Depending on which model your console is, it'll be in different places. On the newer model (the one that has a PC board on the top cover), it'll be on a small PC board on the opposite side. On the older model (the one that has all the PC boards on the bottom), it's sticking up out of the metal plate between the two PC boards(the little clear plastic thing with copper plates inside). Either way, the switch needs to be held down or taped down.(I suggest taping it, but it may not work with the older system.) There are a few little variable resistors (little upright disc-shaped things) on the top left corner of the exposed circuit board (the one with the CD lens on it). Try adjusting those with a small flat-head screwdriver with the system turned ON and a CD on the spindle. Be CAREFUL--do NOT touch the CD while it's moving and keep your hands away from the PC board on the left--It WILL shock you. Adjust the resistors untill the CD spins the fastest. If the CD stops spinning, pull off and then replace the tape. If it doesn't spin at all in the first place, check the tape. Once you get it spinning as fast as possible, hook the system back up to your television WITHOUT replacing the cover. If it reconizes the CD as a game, your done and you can close it up. If it thinks its an audio CD or doesn't read it at all, the resistors need more adjusting. This work can be very trying and dangerous; this method can also ruin your system, but it's the only way to make it work without replacing any parts, but it DOES work. If you have any questions, ask me.
Posted on Jul 12, 2009
Magitek85.When you start up ypur Sega Saturn, It always asks for the Date and Time.
Posted on Mar 07, 2010
  • 148 Answers
You have to try to disassemble your sega saturn, clean it inside...clean the laser lens...reconect the flat cable...and try to check the region jumpers in the back of the saturn motherboard ,
You should check and try to make a laser adjust in the yellow trimpot...this should work!
add me in msn: v4ndre@hotmail.com
Posted on Dec 04, 2008
Where is the transmission control module in a 2002 Saturn vue awd
Where To Find The TCM Module 3 0 Litre Saturn Vue ...
? 1:00
https://www.youtube.com/watch?v=2DehorzZT5E
Dec 10, 2013 - Uploaded by Thinking out side box
TCM = Transmission Control Module Can Be Found Right next To The ... Saturn vue 2002 3.0 v-6 Thermostat removal, Intake, valve cover ...
Shop for transmission control mod... on Google
Sep 25, 2015 | Saturn Cars & Trucks
I have just found my mobile phone LGCE0168 after losing it 6 months ago. How can I restart the Tesco PAYG sim card
I am wondering if you have tried another sim card in your newly found phone?
In theory there should be no problems just put your sim back in and make calls.
I am wondering If Tesco have changed service provider in the last 6 months? If they have it could explain your problem.
Asda mobile changed provider about a year ago from Vodafone to EE and my phone stopped working because it wasn't an unlocked phone. As it turned out I had to replace my phone for one that was unlocked because it wasn't worth the expense and trouble of having the old one unlocked. The old one still works fine on Vodafone and O2.
Just a thought. Another thought is perhaps it developed a fault while it was lost or maybe someone has been fiddling with it in that time.
There are lots of aftermarket phone shops around with specialists to give advice. The Tesco helpline might be able to help.
Feb 02, 2015 | Cell Phones
I have a Sega Saturn with about 15 years. I unboxed it and started to play my games. Everything worked fine until Resident Evil 1. I start the game (everything fine, menu fine, options fine, intro movie...
It sounds like its definitely something wrong with the system. There must be something about this game that the system is having trouble reading correctly. I don't see there being much of a fix for this unless maybe you brought it in to a local game shop and had let look at it.
Aug 12, 2013 | Sega Saturn Console
2003 Saturn Ion won't start in the cold weather
First of all your service light came on so give it a service then have the service light reset then check the thermastac, water levels and the choke is working properly and all the elecric working parts are good
Jul 05, 2017 | 2003 Saturn ION
I bought my Zune 2 years ago and thought I had lost it, but found it. So I have been using it for only 1 year. About 2 weeks ago even after charged, it will only play off the charger for about 45 minutes....
Debbie,
Zune batteries are replaceable. They can be purcahsed for about $10-$15 and with a little knowledge can be replaced by anyone. Check the internet for both the battery and replacement instructions. eBay is a great place to find the battery and most places even include the needed tools
Nov 25, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Lost User Manual for Ryobi Miter Saw. Where can I get directions
Go to RyobiTools.com and click on products or in the upper right hand corner type in your model number and you can download a manual and also parts breakdown for this tool. Dave
Nov 21, 2008 | Saws
I HAVE A FANTOM VACUUM CLEANER MOD.#F1205400. I PURCHASED IT ABOUT 6 OR SO YEARS AGO.IT WORKS PERFECT,AS FAR AS SUCTION, THE ONLY PROBLEM IS ABOUT 2 MONTHS AGO,SOMETHING HAPPENED TO IT AND IT GOT VERY...
You probably have a bad motor bearing. I don't know if the motor is available now or, these older Fantom's are obsolete along with most of their parts.
May 01, 2008 | Vacuums
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
Video Game Consoles & Games Logo
4,937 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
