THE LAST 2 WEEKS WHEN I TURN MY WASHER ON IT TOOK LIKE 3 SECONDS B4 THE WATER CAME OUT, LAST NIGHT WAS THE LAST TIME I WASHED. I WENT OUT 2DAY 2 WASH IT WOULDNT COME ON @ ALL BUT IT WOULD SPIN SO I WAITED SOME HOURS WENT BACK OUT 2 TRY THE WATER CAME ON RIGHT AWAY LIKE IT WAS SUPPOSE 2 & RAN 4 ABOUT 4 SECONDS & STOPPED COMPLETLY BUT IT STILL SPINS, LEASE HELP WHATS MY PROBLEM
No i will not tell u how i fixed the problem & u can help other people, u want my free advice but u were going 2 charge me to get advice screw yall.
Posted on Apr 07, 2008
SOURCE:
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
This is for a 1995 Toyota Camry, 2.2 engine. I
most of the time ive seen a broke car after an engine wash its been 2 things a ruined throttle position sensor they are not water proof not even on jeeps.or a bunch of vater vapor insinde distributor cap [if yours has a dist.]but you could have blown off some hose or wire take a close look for that.
Mar 21, 2010 | 1995 Toyota Camry
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
WILL NOT START
sounds like water ingress to either a control module or the coil pack, check all control box locations eg footwells for water and then check the engine bay for loose or naked wires, dry and clean and possibly cover with a plastic bag etc and it should be fine.
Jun 14, 2009 | 2000 GMC Safari
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Feb 18, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Wife wash it with the week laundry
My mate washed hers thru washing machine, within 3 weeks of being left to dry out, it worked fine!
Dec 19, 2007 | Samsung SCH-u740 Cellular Phone
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
