Question about Estate TEDS740JQ Electric Dryer
Rear drum gasket is rust colored and marking the clothes
The back drum seal is a rusty color and is making this same color makes on the clothes in the dryer, the drum can be moved front to back about 3/8", it seems to be excessive
  • 943 Answers
Hi thanks for the question that part is the rear drum felt that is there to prevent articles of clothing from falling out of the drum this must be replaced thanks the appliance doc
Posted on Sep 22, 2008
My frigidaire dryer keeps leaving these rust color stain on my clothes and keeps putting holes in them. some times stuff gets stuck in this gap between the dryer drum and where the door shuts how can I fix...
replace the drum guides that hold the drum in place these are small plasic guides and they do tend to go with time and use of the dryer this is also what is causeing those rust colored marks on your clothing as well if you are able to message me back your make and model number i can provide you a schematic showing where these guides are located and how to go about ordering new ones for you unit also if you have any further questions message me those back as well and please remember when our chat has concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 23, 2011 | Frigidaire Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Brown streaks on flat, thin items like pillow
Hi Witt and welcome to FixYa. I am Kelly.
The brown streaks are most likely rust. There are drum seal replacement kits you can buy to start anew. The streak source need to be identified. If the drum is rusted your going to have to sand and paint it with an enamel appliance paint. However.... if it is the back of the cabinet that is the source of the rust in the felt seal rub area if you do not allow the paint to dry well before reassembly it will end up flaking off on your clothes.
Here is the drum seal with adhesive:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
Once you in there I would replace the belt and inspect the drum rollers.
Belt:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Whirlpool-Dryer-Belt-item-number-AP2946843.aspx
Rollers:
http://www.appliancepartspros.com/part_details.aspx?part_id=3098345
The belt I would replace... Just make sure if you attempt repair that you NOTE the routing of the dryer belt through the idle pulley to the motor pulley.
If the rollers rotate freely with no teetering froward or aft and do not have any flat spots you do not have to replace them.
Appliance paint by color needed:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Appliance+paint
Thanks for using FixYa
Kelly
Mar 14, 2010 | Kenmore 62602 Electric Dryer
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Clothing coming out stained with rust colored marks-purchased dryer in 2001
The felt needs to be replaced around the drum. When it wears out, this will cause these marks. The felt is the seal that allows the drum to rotate around the door.
Apr 16, 2009 | Dryers
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Kenmore he4 dryer model # 110.85089400
drum seal tends to change to a rust color after a few years of use 2 options replace both front and rear seal(best) or remove drum and try to clean both seals with bleach /water solution or spray cleaner with bleach ..if seals are not worn to bad this may work as a tempory fix
Jul 04, 2008 | Whirlpool GEW9250 Electric Dryer
Rust marks from a stainless steel drum?
If you are talking about brownish colored stains on your clothes, this is actually caused by the drum seal going bad. The drum seal fits around the perimeter of the drum where it meets the rear bulkhead (wall) of the dryer and is a felt type material. One some dryers the drum is reversible and there is a seal on both ends of the drum. When the seal gets old, it becomes brittle and starts to crack and come apart. There's usually a brownish colored pigment that comes off the seal and can get on your clothes. If the seal is worn too much, your clothes could actually be getting caught in the drum between the seal and being dragged. This will also caused brown streaks on your clothes. Now...what causes the seal the wear prematurely are high temperatures. If you do not routinely clean your dryer ducting, your dryer could actually be overheating. This can cause the seal to become too hot and make it brittle over a period of time. Any appliance repair dealer will carry the drum seals for the dryer as it is a common part that requires replacement. If you could post back with your EXACT model number (located around the door opening) I could find a part number and price for you. In addition, I could give you step-by-step instructions on how to replace the seal if you wish to tackle this on your own. It's not a difficult repair and the average consumer should be able to accomplish this task. It will also save you $$ on the long run if you don't want to pay high labor charges of the appliance repair guy. Let me know if I can assist you further.
Jan 18, 2008 | Kenmore 73952 Gas Dryer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
110 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
