Question about Apple iMac G5 Desktop
Mac G5 startup problem
We turned on our macG5 after it being off for 4 days. it was plugged in BUT not on. screen went black and in upper left corner it said:
/etc/master.password:invalidargument. -sh:/etc/profile:invallidargument -sh-2.05b= (blinking cursor)
???????????help. ww need to use this machine asap.
    Scholar:
  • 186 Answers
Try an archive and install of the OS. This will save your settings and files but reinstall the OS. You can do this by booting to the cd and choosing archive and install instead of erase and install. If it happens again, it could be a slowly failing hard drive developing bad sectors, or the less likely of bad ram.
Posted on Apr 25, 2008
SOURCE:
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Display is too large for screen
Hello Dr. Bankert and thank you for contacting Fixya, I will be glad to assist you.
What you need to do is turn off a setting within the System Preferences > Universal Access feature within your Power Mac G5.
To do this, you need to click on the Apple menu icon, located in the upper left corner of your screen. When you do click on that menu icon select System Preferences from the drop down menu:
Then go into System Preferences and look for the pane (icon) entitled Universal Access 9_16_2012_10_06_45_pm.png
• Click on the Universal Access and you will see this view:
Under the Seeing tab, make sure Zoom is turned to Off
This should bring your enlarged screen back to its normal size.
You can now also click the Show All button located at the top of that window (on the left side) to return back to System Preferences main window.
From within System Preferences, select Displays and try selecting a lower resolution like 1280 x 1024 or 1024 x768 for example and see if selecting one of those resolution settings helps to reduce the size of your display window.
Please let me know if any of these simple recommended steps help.
If you have more questions, I will be glad to assist you further.
Regards,
-The MacTechTrainer
Sep 10, 2012 | Apple Power Mac G5 Desktop
Screen went black on startup. only a blinking white line in upper left hand corner
Does this problem occur after windows log in page? If yes, a file of your user profile may be corrupted. Try to do a system restore in Safe Mode if you can still access it.
If you're unable to boot to Safe Mode, then you might need to reinstall the operating system.
Let me know if this resolves your issue or not. Thanks.
May 13, 2011 | Samsung Tablets & eReaders
My G5 tower is no longer recognising my external iSight camera. The only thing that happened was that I switched the G5 off and on again, it was working fine previously. Can you help? Many thanks
Best thing you can do is to determine whether its the port or the camera.
If you go to the Apple in the upper-left corner, and go to "About this Mac", then click "More information", it will start System Profiler. On the left side, under "Hardware", click on "Firewire" and see if your iSight shows up. If you have another FireWire device, plug it in, and see if it shows up there as well. The solution could just be a dead iSight (hopefully!). The worst case scenario is a dead FireWire bus...
If you have a dead iSight, I'd guess that ebay would be your best resource at this point. If its a dead bus, I'm afraid it won't be terribly cost effective to fix it :-/
Jan 06, 2011 | Apple iMac G5 Desktop
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
HOW TO REBOOT MY COMPUTER
just click the apple logo on the upper left hand corner of the screen and choose restart...
Nov 09, 2009 | Apple iMac G5 Desktop
Resolution issue Acer V223w
Hi, I'm sorry to hear you are having trouble....
THis is a tricky one. My first step would be to connect another screen to your G5 and connect your V223w to another Mac... Are you able to do this, do you have access to another system, could even be a PC ( in the worst case )
Ideally, having 2 screens connected to your G5 would be the best situation.
THis way, with one working screen, you can attempt to modify the resolution and refresh rates on the V223w from the good screen, be sure to activate screen mirroring, otherwise you will not have access to the other window of monitors system preferences.
If you can get two monitors connected and mirroring is not an option, then either your monitor is KAPUT or the video card secondary port is KAPUT, try switching the port of the card your displays are connected to. I think they are both DVI ports. If the opposite screen is now working, then you know it's the port on the video card.
Hope this will get you through it.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Grid surrounding cursor and desktop icons
You have accidentally enabled "Universal Access"
Open System Preferences from either the dock or the pull down menu under the Apple in the upper left hand corner of your screen.
In System Preferences the 4th line down should have icons for "System" one of those icons (usually the right most) will be a blue circle with a person in it. This is "Universal Access"
Open Universal access and turn voice over and zoom off.
Feb 28, 2009 | Apple iMac G5 Desktop
G5 imac.. with leopard can not get past sign in
If you've forgotten your password, you can reset it with the discs that came with your computer:
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
Dec 29, 2008 | Apple Power Mac G5
Open Questions:
See all Apple iMac G5 Desktop Questions
Apple iMac G5 Desktop Logo
364 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
