Question about Neumann U87 Professional Microphone
Neumann U87 no signal
I have an older U87 and I haven't used it in a while(maybe 18 months) I tried to get it up and running the other day and couldn't get any signal out of it. It wasn't anything else in my signal path as I checked it all with another mic and ti was fine.
  • papaturner Jan 24, 2009
    I also have an older Neumann U87 with the same problem. When I bought it off eBay from a pawn shop in New York, it worked fine....then it started cutting in and out. Doesn't act like a short at all. When it allows sound to be heard, it actually fades out. Thought it may be the phantom supply, so tried others and the same problem happens. This mic was serviced before I bought it, so I don't have a clue what it could be.
Who serviced the mic? Send the mic to Tracy Korby or Klaus Heyne.
The capsule can get dirty and then behave in the way that you describe. It is possible that a simple cleaning by a professional will bring the mic up to spec.
Posted on Mar 24, 2009
My u87 cuts out when you get to close but comes back on in 2 secs seems to be wind pressure from singing. many thanks Graham
problem is a dirty capsule caused when fogged with humidity from breath it shorts out temporarily. it maybe possible to have it professionally cleaned but may need to be replaced. DO NOT USE FOAM POP FILTERS. Spend the money on a metal one. back off if you wanna save some loot.
May 18, 2011 | Neumann U87 Professional Microphone
My U87 microphone won't power up...no signal. does anyone know why this may be happening?
Was it working fine before it stopped powering up? The U87 is a condenser microphone so maybe the reason it is not powering up is because the phantom power on your interface was not turned on. Plug the U87 into your preamp and then switch on the phantom power (48V) to get it powered up. If that doesn't help, there must be an internal fault within the microphone or in your preamp.
Mar 02, 2011 | Neumann U87 Professional Microphone
Dear All, We use a 12-years old Neumann U87Ai for male voiceovers, with no problems. Recently we experience some slight but annoying distortion, especially when recording loud male voice with lots of...
Usually the distortion is from over gain on the preamp or the spl of the actual voice on the diaphragm have him step back a few steps and try again.
Good Luck, Cody J.
Dec 16, 2010 | Neumann U87 AI-SET Microphone
What resistor do I replace when changing transistors on u-87? Mic has low output now. I replaced the old SK 103 transistor for a 2n3819 transistor from neumann and it came w/ a resistor for matching but no...
Try contacting them through this link and ask to speak to a tech. Write or email them if you have to:http://www.neumann.com/?id=service_servicepoints&lang=en
Oct 19, 2009 | Neumann U87 Professional Microphone
Picking up rf signal on my u87I
Wow that is annoying! Sounds like it's not properly shielded. Check out this site http://www.heilsound.com/amateur/tips/rfi_removal_mics.htm
Jul 23, 2009 | Neumann U87 Professional Microphone
NEUMANN U89 SOUNDS VERY FAINT
Your mixing board may not be supplying 48 volt phantom power, which is required by the U89. Check with a voltmeter from pin 2 of the XLR to pin 1, see that it's 48 +/- 4 volts.
Nov 25, 2008 | Neumann U 89 i Professional Microphone
Neumann U87 is distorting and cutting out
As condenser microphones 'mature' they may accumulate contaminants on their diaphragms, which in turn provide a relatively low impedance bypass for the bias voltage. To check if your microphone may suffer from this effect, hold it close to your mouth and breathe (heavily) a few times on the head. The moisture from your breath will condense , and if there the capsule is compromised by contaminants, or if it has developed other flaws, you will hear an increase in frying sound and/or complete loss of output.
Sometimes the capsule can be cleaned, thus extending its useful lifespan. At the risk of causing irreparable harm to the heart and soul of the microphone, this procedure should not be attempted by an inexperienced specialist! If in doubt, sens the microphone to the Neumann Service Department in Old Lyme, CT or another qualified specialist.
Uwe Sattler,
Technical Director - SEC
May 25, 2008 | Audio Players & Recorders
Need schematic for NEUMANN U87
hi go here and you'll find what you want.
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 04, 2008 | Audio Players & Recorders
Neumann U87 Professional Microphone Logo
491 people viewed this question
Top Neumann Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
drivealot
Are you a Neumann Audio Player and Recorder Expert? Answer questions, earn points and help others
