Back to:
Tags:
Jenn-Air JGS8750 Gas Kitchen Range
JennAire Gas Range - 2 of 4 burners don't light (by 2 users)
posted by ballpark on Apr 06, 2008
Front 2 burners will not light - has electronic ignition and back 2 work fine. Front 2 spark intermittently, but seldom light. I've swapped burners from back to front and still front one's won't light. Am I looking at replacing the 2 spark ignition switches? The spark control module should be fine if the back ones work and front ones don't even after switching them out. Thanks for any help. Actual Model nr is FCG20510w, not the one I had to select below.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 13, 2008
I have a similar problem. I have a gas grill with the 2 burners and the front one will not light but the back one does. When I switch to burners it still does not light only the back burner will light. I tried cleaning the connections but to no avail.
Best Solution
posted on May 29, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had same problem and believe it or not it was caused by a Blue Rhino Propane tank. It was a new exchange tank and because of their "safety" features it would not release a sufficient amount of propane to heat with. Switched tanks and all burners fired up. Have found others on the web with same problem and solution.
PJ
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JennAire Gas Range - 2 of 4 burners don't light:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
When we run the oven self-clean, the oven interior...
When I press "clean" key, it beeps twice, but...
Just came home and I think the power went out while I was...
other burners make a clicking sound when only one burner...
one burner is not working - ignition does not spark good...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
