Acer Aspire 5720 6497 Laptop Logo
A
Anonymous Posted on May 21, 2010
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another charger and it worked fine for a few weeks now the same thing is happening could it be I need another charger or could it be a faulty jack Laptop gets heavy daily use and do I need 65W or 90W charger thankx
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on May 23, 2010
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018056
Points
8362
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
Acer aspire 5720, after erasing everything, still getting "low disk space" message. beyond disc cleans & system defragmenting...Any suggestions?
Hi Brandon, You can try cleaning the temp files Click Start >> Run, then type %temp% Enter, then delete everything in that folder.
Please download CCleaner to clean up your registry
CCleaner Download
My Acer Aspire 5720 wont power up, i have tried it with and without the battery, power goes to the power buttons led and fan for 8-10 seconds and then it cuts out ?
Motherboard problems. It's an Acer and they're notorious for having these exact issues about one year to two years after being bought.
2answers
My IT teacher at college says the problem is the motherboard with my acer 5720 laptop. The screen goes wavey and my laptop stops functioning and it would cost to much to be repaired.But it is only 15months...
Try and sell the parts seperate on Ebay but before doing that call the company you bought it from and see if its still under warranty
Im sure laptops come with a 2 year warranty
If not either list the parts or as a whole on ebay
Garry
1helpful
Acer Aspire 5720 Laptop issues.
It could be the battery. So i'd try to find a store that sells batteries and replace the battery.
Manny laptops will shut off when the battery is dead. So if your laptop works without the battery and only connected to the wallsocket, it's definitely the battery.
With kind regards,
Jeffrey
My aspire 5720 32mb.... crystal webcam
Hi There,
Try reinstalling the drivers from the manufactures website or ring them for advice...
2answers
My acer aspire 5720-4126 won't stay powered up
That means that your power adapter is faulty and needs to be replaced.
Hope this helps.
Spreading brown stain on screen
your LCD panel is damaged, if it is only a year old it should be under warranty, it needs to be repalced.
Hi i have an acer aspire 5720 but the login screen won't come on
Hi.
The Acer Aspire 7520 is a very poorly desiged laptop i also have one which is broken atm.
The best thing you could do is to Refomat and install a fresh copy of windows
You shoud have two recovery disk that you should have burned as soon as you got the laptop.
Put Disk 1/2 into the drive.
Boot up your computer and press ATL+F10 atleast three times.
-Follow the on-scree
n instructions and soon you will be asked to put in the disk 2/2.
At the final phase you will be asked to put in disk 1/2 again...Wait awhile untill everything is install and finished loading and your computer will restart with Facory Defualt Settings.
Please Rate. Thanks
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
