Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer problem I have installed 2 new cartridges in my canon pixma mini 260 and it will only print in blue
    President:
  • 2,351 Answers
Pretend you need to replace the ink again. Open the MP600 so the carriage moves to the center (just like your going to replace the ink). Than power off the printer. Remove the cartridges & look very closely at the copper contacts. (Sometime when you remove the protective tape some of the sticky tape leaves a residue. If you can not see anything than get some house hold alcohol & a couple cotton swabs. Dampen the cotton & wipe the copper contacts on the ink cartridge (Not the bottom) & the copper contacts inside the carriage. Let everything dry. Alcohol does not leave a residue. Return the ink cartridges (good tight fit). Close the lid & power on the printer. Print a test page.
Left click once on the start button, slide up to & click on Printers and Faxes. The Printer and Faxes window will open. Right click once on your MP600 & left click on properties. Click Print a test page. If the colors did not come out correctly than run an alignment through your printer software & try again.
Everything I mention above is based on the idea that your printer was running just fine but you ran out of ink.
Please correct me if this is not the case.
Good Luck!
If I can be of more service, just ask.
Mike
Posted on Apr 06, 2008
Canon MX922 printer: cyan was okay after installing new cartridge, but quit printing blue after a few days. Multiple deep cleanings were no help. Can print head be removed?
You better buy a new cartridge, or you could fix that open the cartridge on your printer device.remove the cartridge and broom with a Kleenex.If you need the driverpleasehere Canon PIXMA MX922
Mar 20, 2017 | Canon Pixma MX922
Canon pixma mini 260 is printig blank photos ink cartridge is full
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Jul 22, 2011 | Office Equipment & Supplies
I have a canon pixma mini 260 i replaced the ink cartridge this morning and its allowing me to pick my photos and its printing but the photos are coming out blank?
its a common problem after getting refilled cartridge....
please insert a new catridge and try again.........
sure u can solve this problem.......
thank u .........
Jul 22, 2011 | Canon PIXMA mini260 InkJet Photo Printer
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Can I print with one cartridge at canon pixma ip1300 with out replacing or installing other cartridge.
Absolutely, the only thing you need to do is to configure your setting to the right appropriate ink, say for example you ran out of black ink you can go to printing properties and select to be printed in blue, in this case the color match will use magenta and cyan to create blue.
1 select your default printer 2 select printing preference from your printer from there you can change the color of your desired print 3 you can select print in color for example or grayscale 4 then print your document.
cheers
Jan 06, 2010 | Canon PIXMA iP1300 Printer
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
Changing cartridge
CANON MINI 260 PRINTER CHANGE INK CARTRIDGES
ENTER
Feb 05, 2009 | Canon PIXMA® mini260 InkJet Photo Printer
The mini 260 printer do not print
rncoral,
go into the preferences of the printer, under the maintenance tab you will see head clean. clean the head and do a nozzle check. If you get nothing after two or three head claens, then the head is failing and will require replacing.
Gremlin11
Dec 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
77 people viewed this question
old marine
old marine
