Question about Frigidaire Kitchen Ranges
Fridgidaire electrolux galaxy series range.Getting error F9. Can`t get the door open.Solution please, Thanks, Tony
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Posted on Feb 23, 2008
  • 1314 Answers
SOURCE: Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Posted on Jul 13, 2008
localwonder
  • 6784 Answers
SOURCE: Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Posted on Mar 24, 2009
localwonder
  • 6784 Answers
SOURCE: there is a code f9 on my ditigal range and the
Hi. this is a door latch failure code. Kindly, check the wiring that is linking the door latch mechanism, to the main control board. If the wiring is connected and the contacts are well, this will lead to a failed door latch mechanism. I would advise to test before purchasing a new latch assembly. Once you have exposed the door latch assembly, use the procedure below to test.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing. If there is continuity, this will confirm that the main control board has failed. Control board failure, in this case, is highly unlikely, but possible.
Posted on Nov 29, 2009
EllaWatson25
  • 725 Answers
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Posted on Jan 18, 2010
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
F9 code will not clear
Hi
Thanks for using FixYa.
F9 error indicates Door latch issue and to resolve this you'll have to check the door lock circuit. If that is fine then replace the clock assembly/Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Amana ACF4215 Electric Kitchen Range
F9 Error- the lock for the self-clean cycle accidently was pushed in the lock position without having the door closed
Hi
F9 error in your Maytag indicates Door latch issue and to resolve this you'll have to check the door lock circuit. If that is fine then replace the clock assembly/Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Maytag Kitchen Ranges
The oven touchpad shows "locked" and beeps 4 times in succession then shows F9
Hi
Thanks for using FixYa. Error F9 in your range means door latch failure and to resolve this issue you'll have to replace the door latch switch or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | Amana Kitchen Ranges
I'm getting an F9 error, how do i reset it. I was trying to clean the oven and i mistakenly opened the door. It started beeping and gave me an F9 error
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$#%@#$%
Apr 29, 2010 | Frigidaire FEF352 Electric Kitchen Range
Fault code f9 appears
Hi
Thanks for using FixYa. Error code F9 means Door latch supervisory- Check door lock circuit or rebuild clock assembly (also called the ERC).
You can clear this error code by replacing door latch assembly completly, before that you can check the latch wiring.
And, if door is stuck and you are unable to open the door then take a long hard wire & make a small hook at one end and insert it from the left side gently for the door latch hook and pull it over to un latch the door. After this restart the gas range and check if code appears again, if its still there then replace the door latch assembly completly.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
F9 beeper beeping door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$@@
Jan 18, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
85 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
