Question about Gateway FPD2275W LCD Monitor
Want product info
I want a flat screen monitor that will accept cables from my dvd player, no computer, no television -- just my movies.
  • 88 Answers
No Monitor had DVD Player Connector But there is a solution to connect dvdplayer to monitor that is TV Tuner Card it costs around 20$ in the market.
Thank U
Posted on Apr 16, 2008
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Is there any way to connect this monitor to a computer that only has an hdmi port
An HDMI to RCA component or composite cable only works for video projectors that are designed to read a computer signal. TVs, Blu-ray players, and DVD players use a different format compared to computers. You need an HDMI to RCA converter. An example is available here: http://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html .
I hope this helps.
Apr 28, 2014 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
WHAT INPUT DO I PUT TV ON TO WATCH A MOVIE USING A DVD PLAYER
Does not matter just use your connection cable from DVD player and identify the name of where you plug into and change source to there. Sometimes it will take a few seconds before dvd screen will pop up.
Dec 28, 2013 | Proscan 32LA30Q Television
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
The LG symbol only runs across the tv screen with cable on not with DVD
Unplug,replug the cable box and the tv about an hour.The tv will reset itself,back to factory setting.The cable box should reboot itself and upgrade it softwares.The tv should work again.
Aug 07, 2010 | LG 32LG30 32 in. LCD HDTV
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at 1800customersupport.com, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Sampo PME - S7: Screen is blurry when using as monitor....but looks good when i play a movie on the pc
could you give more info?? how are you getting the signal out of the computer? have you tried other computers on the same monitor. could be the video out of the comp. do you have another source for the monitor you can use??
Jul 31, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
