Question about Konica Minolta Maxxum 5 Date with 28-80 lens 35mm Film Camera
LOADING FILM INTO MY CAMERA
I Cannot load the film into my minolta x370 correctly,when i load it the way i think it should go and start taking pictures at the end of the roll i cannot rewind the film to take for processing
I went to the public library and got a copy of the manual
Posted on Apr 12, 2008
SOURCE:
My Minolta isn't taking photos at all
Next time you load a film, leave the back open and watch as the film goes on to the take-up spool. You'll lose a couple of frames, but that's better than the entire film. If it is not loading correctly, then a prohibitively-expensive repair is called for. Replace it.
Sep 05, 2017 | Minolta X-700 35mm SLR Camera
The zero (0) keeps flashing on my camera, it says 200 at the top which i think is the speed of the film but it wont let me take a picture. the camera is minolta 505si super DYNAX, help please!!
This is a bit late but it might help!
The manual says this:
If the film is loaded incorrectly, 0 will blink in the frame counter and the shutter will remain locked.
Open the back cover and repeat the film loading steps.
Good luck.
Apr 25, 2010 | Minolta Photography
Film loading problem Minolta Maxxum 430SI RZ
not solution, but a suggestion, something to look for/try.
i think it is trying to tighten it and take up the slack in the spool. there might be little red dots or something like that on the inside when you open it up. you are supposed to have the film go to a certain spot before you close it. normally, the film is sticking out the right length, but you might have to pull it out extra first. you might also have to tuck the end of the film behind a roller or in front of a roller before you close it. look for really tiny diagrams inside the camera, or maybe just tiny arrows indicating which way the film is supposed to wind. good luck with your class!
Jan 20, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta x370 camera, the shutter appears to be stuck ? the film advance lever will not move ?
if you are up to repairing the camera yourself, you may want to remove the film first but cutting it from the lock then rewinding it to the tube (make sure you are in a dark room)...
then move to the small article below...
from PointBreak:
The BIG Minolta Shutter Problem Fix Secret EXPOSED!
The Minolta X-Series have been infamous for having their shutters "stuck" and without the film advancing. The LEDS will light up correctly but the film just wouldn't plain advance when you hit the shutter release button. Frustrating to say the least..but alas..alll is not lost. This has been a very common problem and I'll tell you why.
The X-Series, and other possible makers, contains a/an electrolytical capacitor with 1000 hrs of working voltage. When the capacitor reaches its limit it may fail (bulge/corrode). Whether this was an intentional design concept by Minolta is unknown..yeah right! Basically these capacitors hold a small magnetic charge and that when you hit the shutter release it reverses polarity and allows the film to expose, advance, blah, blah, blah..
OK! What I'm going to explain here will save you anywhere from $10 - $200 (meaning you could buy this info. on Ebay or take your X370 to get fixed at a shop). Vendors on Ebay are hocking this info. from $5 and on up..some are actually bidding on this stuff..DON'T DO IT! They will tell you that it's impossible to locate their "product" which consists of new capacitors and the service/repair manual. Well it took some time and research but I have located everything you need so..
Here it is and ENJOY!
1. Download the X370 manuals from http://www.geocities.com/eskoufos/fmm.html. Cost: FREE!
2. Go to http://www.digikey.com/digihome.html. The part number for the capacitor for the Minolta X370 is: P954-ND (Panasonic P/N is ECE-A0GKS221). The actual spec. on the capacitor is: 4v 220uF @ 85 deg. C(entigrade) (6.3X5X2.5 mm).Cost: $7.00 (includes S/H, min. order was 10 pieces @ $2.00 and they charge $5 for S/H)
3. Unscrew the bottom of the camera (4 little screws) and locate the bad capacitor. It's probablu bulging or leaking.
4. If you don't have one, you need a soldering pen and some standard electrical solder. (Go to Radio Shack or any Hardware store)
5. Remove the old capacitor and then solder on a new capacitor. That's it!
if you have other question just lemme know.
Sep 19, 2008 | Cameras
Camera will not fire with dead battery so you will not be able to advance film to #1.......ck out www.flcamerarepair.com for help
Jun 27, 2008 | Photography
Minolta camera
Check the film pressure plate in the back door whether it has proper pressure and in proper position.
Whether the film lead is dragged up to the required length and its perforations are correct without any damage.
Pull slightly the film and rewind it by hand to check its spool rotating freely
Then it needs service
Mar 31, 2008 | Photography
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
 First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably  because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs  two 1.5v  batteries to work ! )
Oct 10, 2007 | Minolta X-370S 35mm SLR Camera
Compatibility of vivitar lens with Minolta x370
Minolta X 370 is not an auto focus camera so provided you are willing to use the Vivitar lens in manual AND provided the lens has minolta mount , you will be able to use it.
Sep 04, 2007 | Cameras
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
Konica Minolta Maxxum 5 Date with 28-80 lens 35mm Film Camera Logo
160 people viewed this question
Top Konica Minolta Photography Experts
Steven Wander
Steven Wander
pictureman4u
Tony Parsons
Tony Parsons
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
