Question about Tappan TEF242 Electric Kitchen Range
Tappan TEF242BW oven stopped working
Apparently, this particular oven (Tappan TEF242BW) was left on Bake at 400 for nobody seems to know how long... turning it on and off did nothing, unplugging and replugging nothing, breaker was not flipped but reset it anyway still nothing- the range burners seems to work.
The red indicator light doesnt even come on.
am I dealing with a burned out oven?
  • 552 Answers
Have you tried the broil setting yet?
This will tell you if the upper element comes on.
If so, you may have a burned bottom element.
Posted on Apr 05, 2008
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven will not work ignitors glows but the burner dose not fire up.
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Gene
Aug 24, 2011 | Tappan TGF320 Gas Kitchen Range
Tappan Gas Range 36-30612302 oven does not get hot enough
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat to correct tempature that a weak ignitor is the cause 100% of the time
Aug 15, 2011 | Tappan TGF363 Gas Kitchen Range
Tappan 30-3822 will not bake. Top burners and broiler work, oven will not fire.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Tappan 30IN ELEC IGNa Oven
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Sep 08, 2009 | Tappan Ovens
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan gas range is beeping a code
This is what f 2 means for Tappan:
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor
Nov 15, 2007 | Tappan TGF657 Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
493 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
