Question about Whirlpool Washing Machines
Code F9 and FA later - Whirlpool Washing Machines
Thanks for help,it is fixed
Posted on Apr 06, 2008
SOURCE:
New codes for telewest starview please posted ones not working
09/10/09
Telewest 00 = CF 53 0C 33 79 61 71 85
01 = D2 F9 3F 22 0C A7 D6 C9
Oct 08, 2009 | Computers & Internet
Need 5c01 ex cw starview
C & W 5C 01] 08/10/09
00 = C5 BE AF 36 0A 61 91 AA
01 = D2 D1 80 FA 21 85 0F 53
Telewest 5A01 08/10/09
00 = 83 5D12 B8 96 F6 1F C4
NTL 54 01] 08/10/09
00 = F0 0E 91 E0 2D C1 C5 FD
01 = 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Has anyone got the codes for starview box please im stuck!!
CW Keys 5C01 updated 08/10/09 10:35
00= C5 BE AF 36 0A 61 91 AA
01= D2 D1 80 FA 21 85 0F 53
TW Keys 5A01 updated 08/10/09 10:35
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 35 22 0C A7 D6 C9
NTL Keys 5401 updated 08/10/09 10:35
00= F0 0E 91 E0 2D C1 C5 FD
01= 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | Intel CPU
Telewest Codes 08/10/09
NTL 54 01] 08/10/09
New code
these are the latest Keys
Pure NTL (54 01) Updated 08/10/2009: KEY 00 = F0 0E 91 E0 2D C1 C5 FD KEY 01 = 5D 61 B2 C8 E7 DD F9 57
TW (5A 01) Updated 08/10/2009: KEY 00 = 83 5D 12 B8 96 F6 1F C4 KEY 01 = D2 F9 35 22 0C A7 D6 C9
IRELAND CHORUS KEYS (5E 01) UPDATED 02/04/2009 KEY 00 = CE 19 2E 87 80 61 74 90 KEY 01 = AA 26 9E F2 E9 14 D1 AE
IRELAND NTL KEYS (54 01) UPDATED 18/12/2008 KEY 00 = B0 B8 4F 04 E6 5F 87 80 KEY 01 = A3 EB EC 07 D6 49 D2 EB
Ex CW (5C 01) Updated 08/10/2009: KEY 00 = C5 BE AF 36 0A 61 91 AA KEY 01 = D2 D1 80 FA 21 85 0F 53
Awm8143 FA code
Service manual say FA is "aquastop failure- check aquastop switch", (aquastop switch is flood switch located in base of machine), however looking at the parts view of this machine, it doesn't seem to have a flood switch-odd.
F9 is an overflow problem- manual says to check pressure switch.
Both faults seem to indicate either a leak or overflow problem- remove rear panel and check base for any water, which would indicate a leak.
If OK, next step would be to remove front panel (remove wire and spring from around door seal, remove 2 screws holding door lock, remove 3 screws along base- front panel comes off by pulling down and out towards you-can be a bit tight)
Pressure switch is located just above door lock-it has the black tube going to it- remove tube and blow into switch-you should hear it click.
Also check the chamber that the other end of the tube connects to on the bottom front of tub- this chamber can get blocked up and cause overfill problems.
Please note- always disconnect from power supply before attempting any repairs. If in any doubt, best to leave for an expert.
Good luck!!
Aug 11, 2009 | Whirlpool AWM8143 Front Load Washer
Codes for starview box
00. C0 F6 61 87 91 F9 67 57
01. F0 83 35 E5 28 40 49 B2
Dec 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Do you no starview codes telewest for 2/7/08 plz
TELEWEST 2ND JULY
00: A8 7C 45 DC 5B 92 44 F6
01: FA 4B 82 4C 6D C8 EA 8C
GOOD LUCK
Jul 02, 2008 | StarTech.com StarView SV211K 2-port KVM...
F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
May 22, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
302 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
