Question about Sony Cyber-shot DSC-W50 Digital Camera
Reinsert the cassete
When i start the cam it keeps telling me reinsert the cassete
  • 3 Answers
This is for a Dsc-W50 Camera? That would only happen with a camcorder. Have you tried another tape? Sounds like the drive heads are out of alignment
Posted on Apr 12, 2008
Error c31 23
Hi as this goes ther are two things one the heads are totaly gone as you might need to replace them and the rebon on that connects the screan and cam its broken dues to use open and shut the external screan.
Feb 05, 2014 | Sony CCD-TRV238E Camcorder
I am having same problem when i start cam a messege on my screen displays reinsert cassette and i am unable to remove cassett
if cassete is already in your cam den may be its blocking so that why its not opening..like some mechanical issue
Feb 10, 2011 | Sony CCD-TRV238E Camcorder
Error Msg - Reinsert the cassette Whenever I.
check if you have the correct type of cassete
in case you have the correct you need to check
the arm-sensor that check if cassete is in
if it is broken you need to replace it
Dec 05, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Cassete not getting inserted.[message comes as remove cassete]
Does this happen with all cassets???
If So then....
1. try using a head cleaner casset.
2. connect the cam to your p.c. and check it for viruses.
Nov 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
Keeps telling me to reinsert cassete. And i keep doing it nd iot keeps teling me th esame thing
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 30, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
My sony handycam digital 8 285E is showing problem C : 31: 22
Well I have not had this happen in my own Sony 340 8 camera, but I have head of it lots of times.
Make sure your tape is re-wound to start, check that the safe tab on rear of take is not pulled over the hole (it prevents writing over stuff you want to keep.
Jun 05, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Hi: My Sony camera keeps telling me to reinsert the Memory Stick which I do but keep getting the message. What is solution? Thanks!
Dear Friend,
Try Following...you will be Solved..
  • Insert your MMC in to a GOOD card reader and Check .. (any damage )
  • Insert in to CAM
  • If still same,Insert another MMC in to your Cam
  • Still same,Then Check your MMC jack(any Contacts damaged)
  • Then you have to Manual Repair your CAM
YOu are Done..
Is this Text Helped You .. Do Rate Me... YOu can Feel Free Contact me.. Thanks For Using FixYa
Apr 01, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
REINSERT THE CASSEETE
Me also getting the same problem.. but some times it is getting okk...  what i m doing is, put the casset while pushing the cassete hold little bit down.. i think it is due to the improper position of the cassete holder...
Jul 20, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Sony Cyber-shot DSC-W50 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
