Power supply regulator for rca 52" home theatre twin tuner pip
Power supply regulator needs replaced, tv guy said $375 to fix. Model #p52755BA, how do I identify this part and will parts from a pioneer big screen work?
  • 8,617 Answers
No parts from a pioneer wont work. There are roughly 4 regulators for the power supply maybe 5. The sad thing is they cost between 7 and 20.00 , he didnt happen to mention which power supply was affected did he? You would have to check the various regulators out of circuit to determine which one is bad. If its a F.E.T they are hard to check without the proper equipment.
Posted on Apr 05, 2008
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
No sound on my RCA TV, Home Theatere H P, Twin
http://elektrotanya.com/rca_ctc179cm_chassis.pdf/download.html
Please find above your service and repair manual, all is inside this manual.
May 24, 2010 | Televison & Video
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
Nov 24, 2009 | RCA D52W19 52" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
52 inch RCA TV Model P52755BA about 12 yrs old
probably you have glycol leaking on the anode lead, in one off the pic tube, check for wets spots, or pay attention on the chassi where the hv leads are located, be careful
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
RCA Home Theatre TV
Have you checked the fuse? If the fuse is good you have a problem with the power supply which can be repaired. You would need a service manual for the power supply. But that would be a lot cheaper than having it repaired by a shop. Power supply problems usually run about 400 to 600 in a repair shop. When often it is a 20.00 part. If I can assist you further please let me know.
Jan 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power not working
the tv needs to be repaired take it to a tech the power supply is the culprit along with the related circuit.your tv must be repaired by a proffessionl tech good luck.
Apr 03, 2007 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
254 people viewed this question
Top Televison & Video Experts
