Question about Sherwood RX-4105 Receiver
Denon receiver shutdown
My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool So I do not think this is a heat problem.
    Problem Solver:
  • 7 Answers
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Posted on Jan 11, 2009
Power indicator is flashing after volume spiked and unit shut off
You can try a hard reset: Unplug unit from AC mains and remove all cables from unit . Wait about 3 hrs and replug to AC power and redo the cabling. Switch on the unit and see if it works..
Sep 26, 2008 | Denon AVR-1082 Receiver
My Denon AVR3805 shuts down during sound spikes in music. I have to keep the volume at a lower level to keep this from happening. I keep the receiver on a rack in a closet system with fans to keep it cool...
Try a hard reset first unplug all the cords from the ck and allow the unit to reset for 30min and then plug in the cords back.
I will be posting more troubleshooting steps..
Apr 05, 2008 | Audio Players & Recorders
Denton receiver shuts off when there is a loud sound from the show
Your Denon receiver may be going into overload, which comes from playing it too long, and too loud. Try reducing the volume to 1/2 your normal level. If you still have issues or questions, please visit my website at Thank you.
Jul 09, 2012 | Denon AVR-3805 Receiver
My JBL PRX 635 Speakers at all event shuts off during high volume ( No Red Light ) Very Embarrassing during the dance is packed. Volume is always set at one single yellow peak from the mixer and just...
Sounds like you're over driving them. First check to make sure they're on "line level" not mic. Shutting off is amp(s) in speakers going into "thermal shutdown" IE: overheating. According to your description level settings look good - check to make sure speakers are on LINE LEVEL
Apr 12, 2011 | JBL PRX635 Speaker PA Active
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Mar 10, 2009 | Denon AVR-2106 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Apr 05, 2008 | Denon AVR-3805 Receiver
Receiver Shutoff
That may be a clue to your shutdown problem. Disconnect that speaker and see if the unit still shuts down. If it does not, then there is a problem with this speaker,or the wiring going to this speaker. If the unit still shuts down, disconnect each speaker at a time to see where the problem is. If none of the speakers seem to cause the shutdown problem, there is na major fauly in the amp circuit, so the amp will need serviceing or replacement. Good Luck
Apr 08, 2007 | Kenwood VR-4090 Receiver
Sherwood RX-4105 Receiver Logo
224 people viewed this question
Top Sherwood Audio Players & Recorders Experts
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
